200mph
My new shop has an enclosed space under the stair landing going to the attic.
Currently, it contains the sump, sump pump and water heater. The PO also had his 60 gal. upright compressor in there.
The outer wall has fiberglas batts, the inner walls are just studs, and there's nothing under the stairs themselves.
I'm going to put a compressor in this space, and am looking for ideas for noise insulation... I've ruled out molded soft foam as used in recording studios... its expensive, and deteriorates relatively fast.
Fiberglas batts? Rigid foam? both? Something else?
Thanks in advance, Mike
