vavet
I got a 24x32 garage built a few months ago.
I just finished applying the white armorpoxy epoxy this morning, still have to do the topcoat.
I’m thinking about building in storage. There are stock kitchen cabinets I can buy from ReStore or the big box store. There are big box garage units. There are some semi-custom units from online vendors.
How do I work around the way my walls are built? There is a 2 foot concrete block wall on which the 10 foot 2x4 walls are built. There is a step outward from the face of the block wall.
If I simply set the cabinets on the floor, then I have a huge gap behind the upper portion. If I mount upper cabinets, then those would be set back farther than a typical installation unless I shim them out a few inches.
I’m thinking I will insulate and drywall at some point, but that still doesn’t bring the stick built wall out even with the block wall.
I suppose I could custom build some cabinets with a notch to accommodate the way they would set against the wall.
Anyone else deal with this?
