Chuck - Stuck jammed.
rlitman
Long Island
Can you spray some penetrating lube in there?
Just to be clear, you're trying to open the chuck, not remove it, right?
Michael_in_DE
Wilmington, DE
I JUST had this same problem. Bought a dewalt cheap off a yard sale, got it home to find out it was rusted/glued/magically F'n bonded to the jaws.
Tried soaking the chuck in vinegar, no go.
Filled it with and sprayed it with PB blaster, no go.
vice grips on large part, and vice grips on smaller part, no go. Even tried a hammer.
Watched one ******* youtube put a drill bit in the one of the chuck key holes (old style chuck) for leverage. On broken bit later, no go.
I got it unstuck by putting the smaller front piece in the vice and using vice grips on the bigger piece...and wrenching on it like I didn't care anymore.
H
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
Yes open it. It is jammed in the fully closed position I can not put a drill bit in it.
Tried WD40 RP7 type of products and still no luck. I am worried the plastic may break in the vice.
KnurledNut
n/a
If all you else fails, clamp the drill and try breaking the chuck retaining screw. It is reverse thread. A pipe wrench, oil filter strap wrench, or chain wrench should do it.
Edit: Wanted to clarify, While the screw is LH, the chuck is RH threads. So if you go this route, lefty loosey is what youre after with the chuck.
Michael_in_DE
Wilmington, DE
Eh. You may be to that point now. Worst case scenerio, you do break it. Then get a new chuck from the store, or off another drill.
H
HOTFR8
HOTFR8, I can't help you on this one as I have never had that happen..
:thumbup:
Retaining screw ?
To add more the chuck looks like this >
To undo the chuck the bottom piece must slide down before the chuck will undo and at this time I can not move the bottom part down.
KnurledNut
n/a
Retaining screw ?
The screw is inside the chuck. You cannot see it with the chuck stuck closed.
Typically you would open the jaws all the way and use a screwdriver to remove it, and then unthread the chuck. You cant do that with the jaws stuck closed.
So the option i mentioned is trying to break that screw head. This would mean getting a new screw.
It is hard on the drill, but you dont have many options. Make sure the drill is in first gear and reverse.
rlitman
Long Island
... I am worried the plastic may break in the vice.
Probably will. But that chuck is also probably toast already. If the lube and wiggling don't help, even if you get it open, it's got a lot of frustration left in it.
Anyway, you don't want to use so much force that you damage the gearbox in the drill.
The last time I encountered this, I sliced right across the chuck with a cutoff wheel. At that point, the jaws (and everything else) fell out, and I was able to remove it and replace with a new chuck.
H
HOTFR8
OK.
Easier for me just to buy a new drill and I have done that any way but may try your ideas and see what happens as I have nothing to lose.
Can you Chuck the Chuck in a lathe?...
I may have to visit a mates work shop to try that.
You need a 48" pipe wrench and 6 foot snipe.
Sound aggressive but it sounds like it may be the way I have to attack it.
peteco
Hit it with some CRC Freeze-Off Super Penetrant. I have broken loose bolts that nothing else phased. Might work on the chuck. Worth a shot.
Dingleburry
Great white north in an igloo
But on a more serious note.
Id hit it with penetrating fluid, from the jaw end. Then give her a few taps with a steel/brass hammer on the jaw end. Hit it straight on, left, right, up/down. Then re spray with pen fluid. Repeat. Inbetween try losening it AND tightening it too. All you need to do is "break" it free. And tightening it could also work. Try using a punch/chisel and hammer to twist the chuck again in both losening and tightening. Id also try a pneumatic hammer. "Shocking" stuck/frozen stuff works wonders. Just dont bend the chuck. I believe i seen the chuck was plastic? Could get some dry ice and differentially freeze the jaws.
Good luck!
Is it jammed up? As in its been used recently? Or frozen/corroded from not using it?
H
HOTFR8
Fretters
South Yorkshire, England
Couple of pieces of wood, approx. 1' long, and drill a hole in each near one end just a gnats larger than the chuck diameter. Slit both pieces down their length to the hole, then slide one over the bottom part of the chuck, one over the upper, and screw each piece of wood with a screw through the side, to close the slit. You should then have two tight fitting levers to work away at.
H
HOTFR8
OK........I think I could try that.
I had it in the vice but still can not make it budge.
H
HOTFR8
:rocker: Thanks every one. A combination of many of the ideas and it is fixed. I locked the chuck in the vise and set it in reverse then forward and a gentle tap with the hammer as well and it is now working again. :rocker:
:beer: This is what makes this forum a great place. Thank you all for the information. :beer:
Edit: We have a great Brains trust of knowledge on this forum.
SuperCat
Sacramento, CA
Great work everyone and thanks for the thread, HOTFR8, I learned a lot from everyone's suggestions and your solution.
However, this situation begs the question: How can we prevent this from happening? It never has occurred to me that a drill chuck could get stuck. Do you think oiling a drill chuck is a good idea? If so, which oil to use? If oil is a bad idea, what should we do as preventive maintenance? :headscrat
1/2 Cup
Member Emeritus
Shepparton. Victoria. Australia
I try to keep mine clean, a quick blast with the air and with a light spray of CRC, it works for me.
Regards
Ralf99
S.W.Victoria, Australia
Heat or cold can also be your friend - on an all metal chuck a heat gun can be a saviour, but even dunking in a mug of hot water on a composite chuck has been known to help.
B.S.A. (ret.)
Central Connecticut
I suppose it would be futile to ask chuck manufacturers to imbed an appropriately-sized charge of C4 during the assembly process in order for us to avoid these nasty situations.
Just a thought...
APEowner
Sunny, New Mexico
An interesting comment and I can add this drill I have had for many years and never had an issue. I have found Ryobi a good quality product.
That's wasn't intended to bash Ryobi products. I was in a hurry when I posted and probably should have elaborated. What I was intending to suggest was that it might be worth investing in a machinist quality chuck. They tend to be quite expensive (like more than most cordless drills) but could be considered a lifetime investment.
I never liked the chuck on my Dewalt so I replaced it with an Albrecht that I had that was probably 30 years old before I put it on the DeWalt. They run about $250-$300 and are overkill for a cordless but I had it.
I've got a Jacobs brand on my Makita that cost about $150.00 that I bought new. That's what I was suggesting. When your drill dies then you can move the chuck over to another assuming the same mount.
stikman56
Tap it on the very end with a hammer, then try. Repeat until it comes open. Have had this a few times, this will get them open.
H
HOTFR8
I did not read it as a bash on Ryobi. The comments on what you find good are appreciated.:beer:
Followed another post reply and put it in the vice as well as tapping it with a hammer. If you read back you will see it has been resolved.
