Platonic Solid
bullnerd - Since Bees seems to be selling various different housings via the same listing, what name brand is on yours? Pics of the problem area would be useful.
Polymath - I've been avoiding recommending glass tubes as I'm not sure how shatterproof they really are. The 180° beam angle on those will put more light at ceiling height, thus less at workplane, but you should be fine at 9ft. On the plus side, wider distribution will provide more even illumination with fewer fixtures. At $6 per tube, you can hardly go wrong.
Polymath - All recommended 4ft retrofit tubes to date have been plastic tubes. I prefer to see an aluminum heat sink as that is likely to improve bulb life. I don't see the universal wiring or ability to connect to a fluorescent ballast of the tubes you selected as being a pro or con. I just wouldn't recommend using them with a fluorescent ballast.
Your real issue is the lack of reflective surfaces in your space means you need more fixtures or more lumens.
Qty.12 4400 lumen fixtures in a 24x24 with 20|20|20 reflectance = 55fc at workplane
Qty.16 "..." = 73fc
Qty.20 "..." = 91fc
Above figures will be slightly less due to 180° beam spread.
Qty.12 5280 lumen fixtures in a 24x24 with 20|20|20 reflectance = 66fc at workplane
Qty.16 "..." = 88fc
Qty.12 5280 lumen fixtures in a 24x24 with 70|50|20 reflectance = 85fc at workplane
Good catch except it has a clear lens which is undesirable, but this distributor has another worthy frosted lens option:What about these lights from MyLed
https://www.ledmyplace.com/products/t8-4ft-22w-2row-led-tube-3000-lumens-5000k-clear
T8 4ft LED Tube 18W 4000K Frosted 2400 Lumens Single Ended Power - $6.99 (link)
The 5000K shows out of stock. (Free shipping @ $49)
Worth keeping an eye on the LEDmyplace website.![]()
JoeMayo - Bare LEDs have concentrated light output. This causes glare which is sharp and painful even if only seen via ones peripheral vision. The slight lumen reduction from the frosted lens is well worth it for your comfort. The frosted lens also evens out light distribution. Clear lensed lamps cause an undesirable striping effect on nearby walls.
bullnerd - Well that *****. That's some sloppy craftsmanship. Thank you for posting detailed pics and videos. So there are 3 issues:
1. Poor end cap to housing engagement.
2. Excessive lamp holder to mounting slot slop.
3. Tight lamp holder to lamp pin engagement.
Question: Is there a UL logo molded into the back of the lamp holder?
The metal slots for the lamp holders should measure 0.344 x 1.000.
QUOTE]
Yes, to the 3 main issues.
I'll look for the UL stamp.
I can measure those also.
I wasn't thinking, I should have bought one housing from each vendor and then made my decision.
I'll mod these to tighten up the caps.
Surprised to see someone in the US can manufacture something cheaper than China, that's good to hear.
That may not have proven anything, since from recent posts Bee's is selling several different housings via the same add. What you get today isn't the same thing you'll get tomorrow. I should probably pull it off page 1. If the lampholder doesn't have a UL logo on the back I'll definitely remove it.I wasn't thinking, I should have bought one housing from each vendor and then made my decision.
Here is the UL sticker on the fixtures I bought from Bees lighting. I could not see anything stamped into the housing.
This is a good question. Which dimmer, if any, function properly with your chosen lamp needs to be confirmed by the manufacturer. The distributor may also be able to answer the question. Please post results if you do the research.I have a question for all and I searched with no luck. With the above Diva strips and 22W led bulbs can I get a LED dimmer wall switch to dim these? I am running one circuit of 12 and another circuit of 8 and just thought it would be nice to dim these....
Pointer, are yours the Utopia brand also?
Platonic Solid, I would say no they are not as bad as bullnerd. They have a very little play and yes they could be better quality but if they are all like the one I unboxed and put together then I should not have to do any modifications to use them. I seen bullnerd's vid and that is terrible.pointer80 - Thank you for posting lamp holder pics. The UL logo is clearly visible as is the manufacturers logo ED = Etlin-Daniels (link) and part number FL005. I've done business with them for many years and have had very few issues with their products. Do you have the same issues as bullnerd with the tight pin to socket engagement and loose/sloppy lamp holder to bracket seat?
I also have to open some more boxes and see what I find. Maybe I just got lucky on the one I opened and assembled. LOLThat's what I was about to ask.
Maybe I'm doing something wrong! LOL.
I'll have to open some more and see how they go together.
Thanks Pointer.
AP514 - You don't need the wirenuts on the feed to daisy chain. The luminaire disconnect has 2 holes for this purpose. Proper strip length for the yellow Wago 873 disconnect is 0.47.
Post #1004
See Post #1013 for differences between Maxlite and Diva Light housings.
