Garage infrastructure improvements for content creation
thejunkmanadv
I recently upgraded my PC in the garage to something with enough power for live streaming. I made a quick video about it, however I am also going to chronicle other improvements in my garage infrastructure. These improvements for the time will be centered around content creation for Youtube. Things that will help speed up or help in creation of the videos.
Was just wondering if any others here have some nifty rigs or things built to help with lighting, microphones, camera rigs, green screen, ect... If you have pictures, post them up.
Garage PC upgrade Vlog
Falcon67
Merkel, TX
Streaming? PC seems overkill, but I guess for video production. At work they just did some NCAA soccer production with an iPad and a laptop. For video in I use one access point, Chromecast in HDMI 1 and my Galaxy Tab A and I can stream anything - YouTube, Netflix, etc. And pipe the sound through a 1982 Realistic amp into 1980s model Radio Shack speakers LOL. 40" LED 1080P TV was $199.
T
thejunkmanadv
I think I didn't explain properly. I am not watching streams, I am creating them. In essence I have finally "junkyard" PC built a rig that has just enough to encode 2 web cams in HD to send it out to the net. I use Open Broadcaster Studio to manage my equipment and encode. Also I do some audio capture for later use in videos. I am trying to wrap my head around what type of rigging I want to build to attach booms and mounts to to more easily position my mics and cameras.
pgray007
Charlotte, NC area
Get a wireless lapel mic. There’s really no substitute other than a boom (and then you need a sound guy to hold it). I also like creative use of go-pros (eg put one on your ply as your run it through the table saw, hang on the wall for time lapse, etc).
I check out Linda.com for video production courses, and there’s lots of free content from Adobe that is based on their software, but also talks about general video techniques and setup.
T
thejunkmanadv
A lav mic is something I am looking at investing in. I am trying to think through some type of rigging for my various lighting things I have. I have built some rudimentary softboxes. I am thinking about mounting most of this from the ceiling so it is out of the way. Just wondering if others here might have build some rigging of their own for some ideas.
FYI I am not trying to be Stevie Speilberg here, just trying to stream line basic setups when I am filming myself. Sorry for the large pictures, don't know how to scale them down.
Examples of my somewhat janky setups I have done.
Streaming setup
For things like this I haul my editing rig out to the garage as well as my dual monitors to manage the chat and OBS on the fly.
Lelandwelds
Central Texas
I have zero experience on the subject. But, I always thought a length of barn track, 20 mm round with linear bearings, or unistrut mounted to the ceiling would be the sweet set up. Mount a short boom with an adjustable counterweight and a pan tilt camera head.
Might delete the boom and just pan and tilt from a barn track overhead bridge crane.
In my dream version, I use the linear stuff with ball screws and stepper motors from ebay. I would want something joy stick or rheo controlled instead of G code. Having pre worked out g code with arduino might work ok.
Eslader
The lav should be your first investment unless you're always going to be sitting at the bench like in your picture. You have to have the mic close to you in a shop environment if you want to have a shot at getting clean sound. Otherwise, even if there's no equipment making noise, the room is big and there's almost never any sort of sound dampening, so if the mic is too far away you'll get reverb and there's no way to fix that in post without dialog re-tracking, which is the kind of pain-in-the-*** best left to Hollywood.
See that light on the left in your first picture? Run a dryer sheet through several dry cycles to get all the perfume off of it (else it will smoke) and then put it in front of the bulb. You can make a frame out of a coat hanger, then use clothespins to clip the sheet to the frame. This will give you an almost-free scrim that looks just as good on camera as the pro ones that we pay stupid prices for.
Your mic rigs look fine to me as far as capturing natural sound. The swing light mount you have the sticks on is pretty much what we use professionally when we need a movable mount - the main difference is that ours are set up to not squeak (theoretically) and ours cost a lot more. Back in college I did many a radio show with exactly the swing mic setup you have, and it worked just fine.
If your production is mainly you sitting at the bench, then pre-set your lighting in such a way that you don't have to tear it down every time to use your garage. A really easy way to do this is to get black pipe, secure it to the ceiling so there's clearance between the horizontal run and the ceiling, then get clamps to mount your lights with. Never trust the clamps! Always rig a safety wire as backup for if (when) the clamps fail. This picture shows you proper safety wire setup:
Then set your lights for 3-point lighting, explained here:
http://www.mediacollege.com/lighting/three-point/
T
thejunkmanadv
These are all great suggestions! The dryer sheet thing I had not heard of. I am going to try that. I am no stranger to ADR and audio clean up in post. I am well aware of some of my sound deficiency's.
I wish my setup never changed but it does depending on what I am trying to do. A clamping system will maybe help for positioning. And just an FYI, I now have a proper chroma key green backdrop so lighting it will be easier.
I am not trying to be super pro at any of this, just trying to incrementally get better at this hobby and make it easier on myself in setup when the mood strikes me to make a video.
I am thinking about building some things using PVC, would be cost effective and easy to work with. Make some special clamps for various things ect...
Here is an example of some of my best work (be kind), concerning videos I make in the garage, for reference.
Here is my most popular video from about 6 years ago, shot with a cheap FlipCam camera. I think the quality difference is pretty appearant.
pgray007
Charlotte, NC area
I love your PVC idea. If you wanted to get slick, you could throw a couple of pulleys on the ceiling, and have your lighting rig made of PVC and “collapsible” with the right fittings so you could assemble your lights on the ground and raise into place, making the whole setup a couple minutes to take out of storage and deploy, and same to store.
Neat videos BTW. I’ll have to check out your channel.
T
thejunkmanadv
I have some ideas in my head building something like this only suspending the rails from the ceiling and have a drop down tube for clamping accessories to. Thus it can slide back and forth maybe right over the bench area or something. I still need to put some more thought into it. I have a lot of scrap parts and pieces of PVC, angle iron, wheels, pulleys and things from other projects and repairs.
I thought about using threaded pipe for easy connection to the ceiling, something like these. The rigging will not have much weight to it. If I ever get "real" lights that are heavy I will have to go to something steel obviously, but this seems like a low cost to prove the concept. Plus it can kinda bee taken apart fairly easily if I don't like it.
T
thejunkmanadv
Ok, its been a while, but I did a small improvement to increase the functionality to my garage for filming my Youtube videos. I plan to add more to it, but this gives the gist of it.
