Fedwrench
I strolled through Lowes the other day picking up one of those $9.98 stubby wrench sets, when I noticed a set of wrenches on sale on an end cap display. Kobalt currently has what they call their "Cross Form Wrench Set" on sale for $24.98. It's an 8 piece set that has 8, 10, 12, 13, 14, 15, 17, and 18mm plus a wrench rack. SAE is also available.
I played with one wrench on their demo block and felt that the wrenches were different. These are not your x beam or cross force wrenches. These are a little unusual. Its' like they took the open end from a FACOM 440 series wrench and mated it to a partial socket boxed end. The boxed end isn't bent 15 degrees like a regular combination wrench. It's more like a socket. Depending on the wrench size, there's like 3/16 of an inch between the bottom of the boxed end and the base of the wrench beam. The wrenches aren't real long. The 13mm comes in at 6 7/8 overall. The beam of the wrench is comfortable. It's not bulky. There's a slight curve in the beam by the open end that feels like a natural place for thumb or fingers. The jaws of the open end are tapered for improved access. The finish and chrome of the wrenches is very good. Yes, like other current Kobalt tools, Taiwan is stamped on each wrench. The crappy pictures below compare a Craftsman 13 mm cross force wrench to a 13 mm Kobalt Cross Form Wrench to give you an idea of what I'm talking about. These wrenches probably won't make you give up your existing wrenches but, they are different. Next time you're in Lowes, play with the one on display. Try not to turn this into a Taiwanese made tool bashing event and talk about the wrenches.
