Dual bulb fixture issue
jives
Central NY
Hi all;
I've got a standard 2-bulb overhead light. Both bulbs go on when the fixture is turned on, but after about 3-4 minutes one of the bulbs flickers then goes out. Been doing this for a couple of months. I've swapped out the bulbs on several occasions, currently running two LEDs. Could it really be just the socket if it goes on then off?
Muchos gracias.
Shiftless
East Bay SFO
That happened to a '50s vintage 2 bulb bullet style spun aluminum outdoor fixture when I ran LED floodlights.
After I changed back to incandescent spot bulbs, the problem went away. That fixture is rarely used so I don't have much motivation to rewire the whole thing.
J
jives
Central NY
"Standard"??? No such thing.
Okay, common, two receptacle E26, opposing sockets, same socket fails, like this:
ard
Sierra Foothills... California
Ah, I was thinking dual fluorescent.
Check the sockets, make sure the contacts are extended enough to make good contact. Is it the same socket that fails with all the bulbs?
Mr_fixit
Rustylvania
Hi all;
Muchos gracias.
yes, could be.
