Any measuring tools you can recommend for a collision tech?
Ktmrider83
Started a new job at a collision center. Looking for a tram gauge and any other measuring devices to determine which parts are bent. Thanks for any suggestions. We dont have an alignment rack and some of these insurance companies like to do bare minimum, the more I can prove right off the bat the smoother the process goes. Thanks for any help
K
Ktmrider83
Holy **** haha. It's pretty amazing what can be put back together with enough skill.. I am only doing the mechanical aspect of things, subframe, steering, suspension ect..
mbshop
visalia ca
Most manufacturers will have the requirements and tools needed to do the job correctly and safely. Why you don't have a rack is beyond me.
K
Ktmrider83
Yup it's a real time waster not having it in house. You get these cheap insurance companies that want proof the strut and knuckle are bent let's say, when I can't prove it they say start with the strut.. fails alignment, than I do the knuckle..waste of time
rsanter
visalia ca
There is a special tape measure with a thin hook on the end
It is used to hook into a body hole and then measure to another point.
Easier and better than using a standard tape measure
speedpower
A tram gauge will give you most information you need.
If you deal full frame trucks you may need center gauge as well.
Unless you have an alignment machine, you can't tell exactly which suspension part is damaged other than the obvious.
Gmonkee
I do that in the same capacity. Strip the wreck and replace the big hard parts when replacement parts come in.
Sadly it's become nearly all hack work. Budget rules over all and suggestions yo spend more are not appreciated. Get it to pass alignment and you're golden.
I have ten years in already and you just become another cog in the machine. I do what the boss says and my paydays come.
creativecars
Indiana- where horse and buggies still roam
I'm may be sorry I asked, but what kind of 'collision center' does not have a tram gauge? :dunno: :confused:
These things are usually shop equipment and if you want one for yourself then you buy it, but a collision center should have basic shop tools and equipment.
