Soldering fume extractors?
MUD DAWG
Ontario, Canada
Once in a while I'll have to do some soldering on a bench in the basement, and I'm looking for a fume extractor. A fan, and a vent straight outdoors would work great, but I don't want to cut a hole in the house or add more heat loss. So next best option I guess is a desktop fan.
What do you guys use? Seems really easy to make one and add a carbon filter to it. But how well do the desktop fans really work in filtering the smoke and just recirculating the air?
Thanks
unslow1
Illinois
Do you have any windows to exhaust it through? Maybe a furnace exhaust to pipe it through? Something like a kitchen or bath exhaust to a dryer vent tube directing it.
MUD DAWG
Ontario, Canada
Tying into the other vents is a bad idea. I'll be creating back drafts, and will end up pushing dryer fumes into the basement, or solder fumes in the kitchen or bath. I'm pretty sure this is against code, and for good reason.
I could make a temporary window insert to use when I solder, but it'll be a bit of a pain and eye sore.
Lots of big name manufacturers create table top re-circulation fans to deal with solder fumes, so it must work, but I can't find any good info on their effectiveness.
ScottsGT
Lake Wateree, SC
Years ago a coworker hot glued a "4 pic fan to a 1' long by 3" diameter PVC pipe to pull fumes away from his face. Mounted it to an articuling arm to position it.
Sine Swept
I just built one for my shop bench, it is only temporary but seems a good thing to have. I have a 2 foot section of 3" pvc that I glued a small piece of plywood to the size of a PC fan which I mounted to the bottom. I used an elbow at the top and glued it. I have another 2 feet of tube that I put inside the elbow and vent to outdoors. It only draws 1/4 amp of power for peace of mind.
tym
I just try to keep my face from being directly above the work.
Not really the best solution.
Didn't there used to be little tabletop air purifiers for smokers? Maybe something like that would work?
mrborohachi
Berdoo Route 66
Just buy the foam filters and rig up a larger version of a PC fan. The ones at my work barely worked. I had to have the PC boards I was soldering within 2" for the smoke to be pulled away.
Bert_
NW Iowa
I've never used anything. If your worried just get a small fan to set on the bench next to you, it's not like your doing production soldering for hours on end right? The fumes are minimal.
MUD DAWG
Ontario, Canada
I assume this is the same thing I'm talking about. Probably just a fan, with a carbon/charcoal filter.
I have a good size fan in a box. I'm doubtful a small PC fan would do much either.
No production assembly, but I don't want those nasty toxins in the air, especially in a basement. In the summer time, in the garage with the doors open, or fan blowing, it's no big deal. But in the winter, I'd rather reduce that stuff in the house air as much as possible.
Sine Swept
I soldered 2 alligator clips to a piece of mechanic's wire and mounted them below the fan to hold a wire there while I solder it, much better than holding your breath.
