Not in the garage persay, but the driveway outside the garage (good weather was had today). Went out about 11:00 and started reorganizing the garden shed to get a few more things off the floor, didn't get it swept out because I got sidetracked and decided to tackle some of the leaves in the yard as well as the neighbours place (I do maintenance work for them inside and out). So I gassed up the rider, mulched up a bunch of leaves and then did a second pass with the bagger to pick everything up. This machine doesn't like to chew the leaves up very fine if you just go for the bagger right off the start, so a second pass was necessary.
Once I got the leaves taken care of next door, I wheeled the mower over to the side door of the shop to do some neglected maintenance and winterization type chores to it. cleaned out the larger chunks of grass from the bottom of the deck (there really wasn't much up there), and cleaned out all the grass/leaves from ontop of the deck, changed the oil and reinstalled the deck, put sta-bil in the tank, topped it off and then drove it over to Grandma's place to cram into the shed for the winter.
I think I'm going to call it a day...
