The making of a table
R
RivennHewn
PNW
Those are nice scissors. You have some nice vintage stuff. You've been getting so many things done, maybe you should stay on nights.:eyecrazy:
I do like vintage toys. Seems I'm obsessing with sharpening them these days.
Wearing my finger tips out lapping chisel and plane blades on my diamond plate.
It's nice to have a friend with a Tormek. They are crazy cool, but stupid expensive.
Qj5C
f0AE
drivesitfar
Riv: nice picture of your sharp chisels.
I agree you seem to get a lot done while you are on NIGHT SHIFT so guess you can sleep when you die. :evil:
I'm not sure how thin you might be able to cut some of your slabs, but a friend of mine makes vintage signs mostly out of old wood cabinet wood, but she had some of these pieces with bark on them from her daughter's wedding that might interest you if you might have a need to make a sign.
cheers and keep up the great work and I'm enjoying all the projects you are showing off.
R
RivennHewn
PNW
Mixed up a little cocktail this afternoon.
My favorite furniture finish: equal parts Spar Varnish/ Tung oil/ Turpentine.
Love the way my shop smells while applying this finish.
zj95
That nasty crack doesn't look so bad now, does it?
qYnv
Ready to leave my workbench
IC4I
drivesitfar
Riv: when i first saw the crack I thought it was fatal to your project. did you fill it with epoxy or just leave it be? maybe one of those butterfly type holders that you see so often in slab tables if it gets worse?
care to share the ratios of your mix that you finish your wood with cause it looks great?
still working nights? getting any sleep?
stioc
SoCal
I have no idea how I missed this thread! Awesome work! would be great to see your other random projects linked in your signature for easy finding (MR2, dually etc).
R
RivennHewn
PNW
Thanks Drives,
I don't use epoxy for this type of application. Epoxy turns into a solid. If the slab continues to move/crack, the epoxy fails.
I use a polysulfide rubber type product that remains flexible. As the wood moves, so does the filler.
I thought about routing in some butterflies, but I'm kinda over them. You see too many. I did route in some steel plates on the underside to help stabilize the top.
The finish is equal parts of Tung Oil, Varnish, and Turpentine.
stioc,
Thank you,
I like the idea of adding the links. Will do.
drivesitfar
Riv: thanks for the wood treatment recipe and your thoughts on the CRACK. to get the finish you did on that little table did you put a few coats of your recipe on it and is your shop heated? about how long to dry?
what's next or are you back working on your truck?
R
RivennHewn
PNW
I put two coats on. The turpentine takes the oil/varnish deep into the wood, then evaporates. The second coat evens it all out.
It’s not a high build finish that stays on top of the wood.
Leaves wood looking natural, not plasticy like poly **** finishes.
The biggest reason I like this finish is that it is super easy to repair.
A simple re-wipe, and most scratches just disappear.
As far as what’s next? I dunno, nothing is speaking to me yet.
dwysywd
SE Michigan - Romeo area
Here's another little leather project I did while back. A bullhide sheath hand stitched with deer sinew. Copper rivets hold the belt loop on.
The knife is a Robeson that I picked up on a trip through the Goodwill with my kids. I've never seen another knife with the texture on the blade.
Would love to know what year it was made. I've done a few google searches, and there is info on the company, but nothing I've found on this style of knife.
el-e
ARWv
5Qbh
Riv, strangely enough, I was catching up on this thread, saw the knife, though, hmmm, that's cool. Then I'm reading small Russian garage, by Vieux. That led me to Stas26, where someone comments about reading www.siberiantimes.com, where curious, I clicked to see what it was about... Low and behold on the front page of Dec 1 there is a YouTube video...I kid you not, of a textured blade being made. Hope you like the video and hope it helps you solve some of the mystery.
R
RivennHewn
PNW
dwysywd,
Thanks for posting the link. I got a little nervous watching him chop wood, thought a finger was going to go flying.........
I watched a few of his vids.
He makes some nice tools, and has some nice toys.
R
RivennHewn
PNW
This one has all the right key words.
Live edge, tree round, slab, industrial, casters, Shou Sugi Ban, char, urban logging, salvage, recycle, reuse, repurpose,
Did I miss any????
Dnv9
42G7
V68F
I believe it's time to retire my torch, or just use it for weeding and melting ice:willy_nil
R
RivennHewn
PNW
Thanks Royce.
I decided I wanted to sand out the other table a bit smoother.
I wet sanded it with the same finish mix, and a 220 grit sponge.
Came out baby **** smooth.
wWFh
R
RivennHewn
PNW
Riven, well done..:bowdown:
Thanks 1/2 Cup,
Always good to hear from you.
I didn't know I needed a new scraper this morning when I woke up, but it seems I needed a scraper. Not no store bought scraper either. No, I needed a hand made scraper made out of scraps in my shop.
Had some hot rolled off cuts. Started cutting and then some heat and beat.
71pR
Then I riveted some old brass from my old fire place screen.
beqo
I kinda like how it turned out.
G4Eq
It was all shiny. I don't like shiny much, so I blackened the steel. It dirtied up the brass a bit too.
IuPV
R
RivennHewn
PNW
I'm starting to question the sanity of spending a lot of hours on something that I could have bought at the store for under $10.00 :lol_hitti
A close up of the brass and steel handle.
tOZB
Put a slight offset on the blade so it lays flat on a table.
6YfX
Originally was intending this to be a square edge scraper. Seems more like a chisel edge cutter now.
Gy2y
To protect that edge I spent an hour honing, and my fingers, I made a leather sheath for it too.
cntq
At this point, I figure I'm a couple big ones in the hole:dunno:
R
RivennHewn
PNW
In the land of make believe, I'm a blacksmith. :rocker:
Playing around in the back yard on a nice afternoon.
YepD
bV6F
76bu
Rough shape coming out looking more like a mini scimitar, but sometimes the hammer knows more than me.
R
RivennHewn
PNW
Royce,
This is just a scrap of hot rolled. Probably won't be a knife to keep, as it most likely won't take/hold an edge all that well.
More of a practice round. Timing and coordination of hammer blows. Pulling or pushing with the hammer, angle of attack, which hammer to use for what.
There is too much to know, and I'm barely scratching the surface.
Strouty
Southern Maine
Looks like lots of fun!
I have a question you may be able to answer. I bought an old butcher block top, someone had sanded the finish off and I was thinking about using it for a desk. Have you ever stained one a color? I am thinking about Blue. Just not sure how it will turn out.
Strouty
Southern Maine
Thanks for the tip on the dye, looks like a great route to go. The top is by far perfect, someone started sanding it already and got a bit carried away. It has a slight cup to it, so the top is convex and a few seams are showing signs of spreading. I figure for a desk it will be fine. Here are a few pictures of it.
R
RivennHewn
PNW
Every butch block top I've ever had, or installed has had some splits in the joints.
Finish sanding it out, use filler is you care to. A test piece is a good idea, some fillers take stain/dye better than others. Always important to test all the products together to avoid problems with your finished piece.
That's going to finish out nicely. What are you going to use it for?
I'm thinking I'm liking the idea of the blue aniline dye. Post up pics of your progress!
R
RivennHewn
PNW
Got to hang out with my anvil and hammers again this afternoon.
I'm pretty happy with it, just a tad more grinding and honing. I've already started a sheath for it as well.
OI5q
JIlO
EzMj
Strouty
Southern Maine
That came out great. I have always heard that good steel for things like that is old leaf springs from trucks. You should be able to get it cheap too. I would look at shops that specialize in springs, they may just give you some of it.
That top is for my computer desk, I plan on doing more butcher block, so this is my trial run. I don’t think I will fill anything, it just adds character. If it was my kitchen, I would not want any gaps, but in my office it isn’t really a concern. I will post pictures of any progress.
