Saxaphool
Delmar, MD
Making a grooming tote(basically a small wood box with a handle to carry horse-show stuff to the jumping ring) for the wife for Christmas. Has some cherry boards I bought eons ago for a long forgotten project that I'm using
Joshua_Russo
Huntsville, Alabama, USA
Shop cat storage, Mark I.
Sent from my VS988 using Tapatalk
pinesdune
Manitoba, Canada
polexican23
burbs-Illinois
I learned how to ruin a brand new pushbroom.
note to self... dont use new broom to sweep up wet polymeric sand unless you are going to hose off and clean the broom properly as soon as you are done.
kaymccampbell
Upstate New York
Got the wall mounted, enclosed lift pump done. It's got emergency shutdown, low air lockout and it's all contained in a nearly flush mounted wall cabinet. You hit the main.power, open the door, run the lift, shut it down and close it all up nice n neat. N safe from flying ****.
dittle fart around
Vancouver, Washington, USA
That's a very nice jeweler's bench the cat's working on. We had to get rid of my father in law's bench. He was a jeweler and watchmaker for 40 years and wanted his bench to go to a new person learning the trade. Sold it to a kid in San Francisco with his complete set of tools for $1000. Found the kid through a watchmakers school in Seattle.
:beer:
C_F
Utah...SNOW BLOWS!
I picked up a couple of the HF Pelican rip-off cases recently. I made one up for my Foxwell NT510. I figured I shouldn't just throw a 170$ tool with another 140$ of software in it in the trunk to crash around with everything else.
View media item 77931View media item 77932
I think these cases are pretty nice for how cheap they are. This one was 9$! I got a bigger one to put all my camera gear into for doing video. They are not as good as Pelican but I don't need a Pelican for this anyhow. I've seen some Pelican cases at work with instrumentation in them mounted under a machine for a thousand hours of endurance operation. The case is battle scarred and damaged and the stuff inside is clean and pristine. I've also seen people make up a Pelican case for some equipment to ride inside the cab behind a seat for a month and the case looks brand new when it's done. The HF wouldn't replace a Pelican in all situations, but it still seems pretty well built and protective and is an insane amount cheaper.
I am going to have to borrow this idea, thanks for posting!:thumbup: My automotive code reader currently resides in an old cardboard box, a Pelican case will be much better.
isb cornbinder
That’s going to be a fun truck! What years the old “corn binder”
1952 L110 shorty pickup, 4X4 in answer to your question
A Craigslist shopper called yesterday and came by this morning to see a folding ramp I had for sale. I was about to ask him to leave because there were too many really dumb questions and then the daily grinding on the asking price. I finally said, "Do you want the ramp or not?" He coughed up the cash, we loaded the ramp in his truck and just before he left, he had to ask, "If I don't like the ramp, can I bring it back?" I hope he likes "*** and travel."
Joshua_Russo
Re: What did you do "IN" your garage today?
[emoji481]
That's very cool you found someone in the trade to use the tools.
Mine is in rough shape, water damage to the top and inset panels, a road side find. It's just so cool and the frame is solid, I've used it for nearly 10 years (moved it from AZ to AL) all the while still planning to to a restomod some day. Would love to actually replace the delaminated plywood panels. I also picture a heavier solid top and using it for design work and leather work maybe.
Do you know what the various shaped holes in the top were for?
Course, once I fix it up, what do you want to bet the Missus will want to bring it in the house and decorate with it? 🤣
LS6 Tommy
Northern NJ
Not really in the garage, but out in the driveway in front of it. Swapped the summer rolling stock for the winter on the DD WRX.
Tommy
oldmxracer
Now, that made Me laugh !
dittle fart around
They come with a lathe, an articulated light and lighted magnifying glass. I guess the lathe is the hardest to find. Most of the drawers and cubbies are for specific tools and accessories. :beer:
Joshua, I have re-glued laminated antique ply back together, most recently the back of an oak machinist box. Its a painstaking process, but doable... Figuring out the clamping for sheet areas is the hard part, but once setup its just waiting for the glue to dry...
Joshua_Russo
Really. Hmm.
Gluing in place or disassemble?
How do you keep from gluing your clamps or cauls to the plywood?
I did it in place as it was only the one side and fairly thick.
Wherever I was at risk for glue on the clamps or cauls, I used wax paper between.
It is sometimes a two person job to set the clamps as it was often 2X spacers, 2X4 "Pressure bars" and bar clamps on those. So yeah, entertaining...
An example:
Joshua_Russo
An Example:
OK thanks, never considered that. It's at least worth evaluating if the outer layer will survive the attempt, would prefer the original material anyway.
If you have access to a steamer, you might heat the really buckled parts, then slowly clamp them flat, then, even if the spring back a bit later after cooling, you should at least have reduced the buckle.
Iroc-Z
New Germany, MN
Started finishing my garage walls
PhantomEB
Medicine Hat, AB, Canuckistan
Been working on my 21-22 gallon fuel tank for my off-road truck.
Got almost all day Saturday to play some more so picking up some unistrut track so I can get the tackwelded tank under there and cycle the suspension again to see if the differential hits or clears this tank.
Phantom, Your baffle need some holes, or better still a one way gate from the "open" side to the pickup side at the bottom...
I'd also consider a side to side vent at the very top of the baffle.
Or lose the baffle complexity can get race fuel cell foam suitable for gasoline. Are you putting in an access plate on top like fuel cells use?
iowa4x4dieselman
My truck decided to chuck a u joint cap going 70 down the highway, so after the tow back to the house and getting the wrong part once. Driving 20 minutes to get the correct part since auto parts store in town was now closed, it’s back together.. it sure made a hell of a racket when it hit the bottom of the cab. Lucky it didn’t fully release and smack the airdog fuel pump right next to it!!
Garagetime
New Hampshire
started to put the rear end in my hot rod.
Crazyjake8493
Upstate NY
I made some new TIG rod storage tubes from 1-1/2" PVC, and organized my plumbing fittings in yet another HF parts storage case. Tomorrow I plan on making a rack to hold the TIG rod tubes, and maybe draw up some plans for a much needed cabinet for my HF storage cases.
sixty4
CT
Changed the hydraulic fluid on my Fisher plow, made a mess cleaned it all up, then plowed the driveway.
