Saxaphool
Making a grooming tote(basically a small wood box with a handle to carry horse-show stuff to the jumping ring) for the wife for Christmas. Has some cherry boards I bought eons ago for a long forgotten project that I'm using
No, not that I know of. [emoji16]I've seen you post some Toyota stuff on here and see you're from Huntsville. Are you kin to Scott Russo?
Shop cat storage, Mark I.![]()
Sent from my VS988 using Tapatalk
I did an hour of research on something called some kind of ----hub. Second, I found a company that makes a slip yolk eliminator for an NVG 241c transfercase. The TC is behind a Cummins 4bta powered TH475 and going onto a 1952 L110 IHC pickup.
http://www.jbconversions.com/products/sye/np241c_short_sye.php
Agreed! Too bad I can't make one of those for my dog to get her up and off the floor and out of the wayThat is Awesome!
I picked up a couple of the HF Pelican rip-off cases recently. I made one up for my Foxwell NT510. I figured I shouldn't just throw a 170$ tool with another 140$ of software in it in the trunk to crash around with everything else.
View media item 77931View media item 77932
I think these cases are pretty nice for how cheap they are. This one was 9$! I got a bigger one to put all my camera gear into for doing video. They are not as good as Pelican but I don't need a Pelican for this anyhow. I've seen some Pelican cases at work with instrumentation in them mounted under a machine for a thousand hours of endurance operation. The case is battle scarred and damaged and the stuff inside is clean and pristine. I've also seen people make up a Pelican case for some equipment to ride inside the cab behind a seat for a month and the case looks brand new when it's done. The HF wouldn't replace a Pelican in all situations, but it still seems pretty well built and protective and is an insane amount cheaper.
1952 L110 shorty pickup, 4X4 in answer to your questionThat’s going to be a fun truck! What years the old “corn binder”
That's very cool you found someone in the trade to use the tools.That's a very nice jeweler's bench the cat's working on. We had to get rid of my father in law's bench. He was a jeweler and watchmaker for 40 years and wanted his bench to go to a new person learning the trade. Sold it to a kid in San Francisco with his complete set of tools for $1000. Found the kid through a watchmakers school in Seattle.
[emoji481]
A Craigslist shopper called yesterday and came by this morning to see a folding ramp I had for sale. I was about to ask him to leave because there were too many really dumb questions and then the daily grinding on the asking price. I finally said, "Do you want the ramp or not?" He coughed up the cash, we loaded the ramp in his truck and just before he left, he had to ask, "If I don't like the ramp, can I bring it back?" I hope he likes "*** and travel."
Mine is in rough shape, water damage to the top and inset panels, a road side find. It's just so cool and the frame is solid, I've used it for nearly 10 years (moved it from AZ to AL) all the while still planning to to a restomod some day. Would love to actually replace the delaminated plywood panels. I also picture a heavier solid top and using it for design work and leather work maybe.
Do you know what the various shaped holes in the top were for?
Course, once I fix it up, what do you want to bet the Missus will want to bring it in the house and decorate with it?![]()
Really. Hmm.Joshua, I have re-glued laminated antique ply back together, most recently the back of an oak machinist box. Its a painstaking process, but doable... Figuring out the clamping for sheet areas is the hard part, but once setup its just waiting for the glue to dry...
OK thanks, never considered that. It's at least worth evaluating if the outer layer will survive the attempt, would prefer the original material anyway.I did it in place as it was only the one side and fairly thick.
Wherever I was at risk for glue on the clamps or cauls, I used wax paper between.
It is sometimes a two person job to set the clamps as it was often 2X spacers, 2X4 "Pressure bars" and bar clamps on those. So yeah, entertaining...
An Example:
Good lord, I actually do have a steamer. Genius!If you have access to a steamer, you might heat the really buckled parts, then slowly clamp them flat, then, even if the spring back a bit later after cooling, you should at least have reduced the buckle.
Reclaimed some space. Bought a fitted cover for my lawn tractor and moved it outside to a leanto.
Finally after 2 years I mounted my Dewalt Chargers.
