Run Stihl Blower In Freezing Temps?
BleedingBlue
Indianapolis
I own a Stihl BG-56C blower and I am trying to determine if it is safe to run in freezing temperatures. I would like to use it to blow my driveway/patio when we get small amounts of snow.
I have read some models have a cold temp switch/setting, but I dont see anything like that. I have also read the air filter getting frozen could be a problem.
I cant imagine the blower engines being significantly different than the chainsaw ones, which obviously are meant to run in very cold temperatures.
Can anyone provide any insight?
tarmy
Nor Cal
I run mine down to zero...blowing snow and pine needles off deck and drive.
Never heard of any issue. Same with chainsaws.
There are two levels of Sthil...pro line...and homeowner. All my saws and my blower are all commercial series. They cost a fair amount more...but have (usually) higher horsepower engines...and no restrictions I have heard of...
BleedingBlue
Indianapolis
Thanks for the quick reply.
Mine is definitely in the “homeowner” line, so I don’t know if that makes a difference.
kwschumm
Olympia, WA
I've always done this with my Stihl blowers and chainsaws and have had no problems. Sometimes they start a little hard when it's that cold though.
AA/FC
I run my Stihl BR-600 magnum backpack blower in all temperatures. I blow light snow all the time at any temp. Never a problem. It is a commercial piece of equipment, however.
rlitman
Long Island
...I have read some models have a cold temp switch/setting, but I dont see anything like that. I have also read the air filter getting frozen could be a problem...
That switch in on the backpack models. I don't think they have one on the handheld blowers.
The issue would be with continuous use causing icing inside the carb (not the air filter). I wouldn't worry about it for your purposes.
I have several Stihl blowers, and a power sweeper of theirs (with the rubber paddles). The should all work on snow in theory, and though I've tried both methods, I've had no luck with either.
The blower will move powdery snow (it isn't worth a damn on the heavy slushy snow we get 90% of the time), but around here, when it's cold enough for the snow to be powder, its always been breezy enough that the first snow I blow usually ends up coating me, turning me into the Stay Puft marshmallow man. The sweeper doesn't help enough with the powder, and while it will move slush, it only moves it a few inches, and really doesn't save a whole lot of effort. Neither is at all helpful on crusty snow.
BleedingBlue
Indianapolis
Just used it to blow some snow for about 10 minutes at ~30 degrees with no issues. Thanks!
kbs2244
Go for it.
I use my electric blowers in below zero temps all the time.
I prefer sunny days, but that is for my comfort, not the tools.
James-W
Southeastern Wisconsin
My buddy uses his to blow light snow off the front porch and the driveway. Never had a problem once it was running, getting it started is sometimes a problem though.
chaosracing
Kutztown, Pa
I just used a Stihl BR600 backpack blower and 2 BG86 handhelds to blow snow today. We never had any issues.
One suggestion, remove the spark arrestor though. He did and never have an issue. If not, they block up and then they do not run right.
midwestcj
Colorado Springs
There shouldn't an issue with running the motor in the cold temps.
One thing you can do. Bring it in the house the night before a snow so it warms up. It'll start easier and run better from the start if it's warm to begin with.
Shawn S
Brookings, SD
I have 2 handhelds and 2 backpacks that we use for snow removal every winter. Never a problem.
I love a good crisp February snow 1" or less. The blowers make quick work of it!
PWC Repair
Arkansas
2 strokes are hard to start in freezing temps. And let it warm up good first. After a good warmup, no problem.
like2wheel
On an as needed basis
I have a Ryobi that I use in the winter to blow the snow from the hoop of firewood I keep on the porch.
I have to richen up the mixture screw on the carb to get it to run right in the cold.
Not good to run an engine lean. Especially a 2 stroke.
ken w.
Western New York
I have the same model and I'll blow a small layer of snow around my garage door so it wont blow in. It's hard to start when that cold. I spray the air filter with a shot of carb cleaner and it starts quicker , but you need to let it warm up.
petee_c
KW area, Ontario CANADA
I have the Stihl Kombi system. Homeowner series. I run it in the winter with the blower attachment or sweeper attachment for my outdoor rink... No issues...
Aqua-Andy
This. Two strokes do not like to run lean and it will need more fuel at 0 degrees than at 70 degrees. Pull off the limiter caps and learn how to adjust the carb and the engine will be much happier. you can purchase tool kits for around $20 that have all the special drivers for the mixture screws.
jvitez
Big Sky Country, Canada
I've used my Stihl handheld in the winter for years. When it's really cold (-25-30°C) I have to leave the choke on just a little, still runs and blows fine.
RH2
If anyone watched the bulls game, the ground crew was using sthil blowers on the yard lines.
bowhuntr311
North Central Minnesota
Lots of the guys in my area that do snow removal use back pack blowers for decks/walk ways.
I use mine every chance I get for snow removal. I just put it in my heated garage to dry out when Im done. I doubt very much snow gets sucked through and accumulates inside of the blower but I give it chance to dry out.
midwestcj
Colorado Springs
If you're concerned about running too lean, then do what JVitez does and keep the choke on a bit.
Miss the Pontiacs
Saskatchewan Canada
I use my Stihl all the time for light snow. I just let it warm up a bit and then do my driveway and the neighbours on both sides of my home. Mind you I am using the Stihl mixed fuel which is something I might not do in the future. But using this fuel I never have any issues with starting or operating either the blower or chains saw. Just a little expensive.
SARG
Northeast
The "winter" setting for the backpack units is just a metal "door" that you put over the carb intake by removing a screw and shifting the plate over so it closes a portion of the carb intake & refasten.
Essentially just choking the engine a tad.
Jhoff310
Perrysburg Ohio
I have never had a problem running a 2 stroke when its cold. I ran by backpack blower yesterday in 25 degrees with no problem. I run my chainsaws to below zero. I dont change my gas...I use optimal-2 in all of my 2cycles. I can of 2 cycle for everything
jd_1138
NE Ohio
Do engines run leaner in the winter due to air pressure differences? I'd assume the cold weather would be good for engines except if they do run leaner.
MoonRise
Not air pressure difference.
Air density difference due to the lower air temperature.
Cold air = more dense air = more air compared to fuel setting on carb
Which means a lean condition on the air-fuel mix.
rentalman
Bear Lake, MI
I have sold Echo bp blowers to the railroad for years to blow snow from the switches(easier then pulling a tow compressor around).We don't do anything special to the carbs.
The blower comes with a baffle disc to redirect air going to the blower fan. This is to prevent cold air being drawn across the operators back.
