So my single car garage workshop area was wired by the builder's electrical group in 2015. This wiring runs through the ceiling of the unfinished basement enroute to this attached garage. I hard wired my compressor and all works well but I was surprised that the 240v wiring was not copper. There are qty 4 240v circuits in this garage current. 3 of the circuits use the same wiring and 1 is a different brand.
The writing on the sheathing of the 3 similar wires is below:
PRIORITY WIRE 3C 6awg (13.3mm2) 1C AWG (13.3mm2) AL AA-8000 Type SE STYLE R XHHW-2 XLPE 600v SUN RES (UL) E302630 2014 03764ft XQ
The sheathing on the other brand that was used:
ENCORE WIRE CORP TYPE SE STYLE R THHN or THWN CDRS 600V 3 CDRS AWG AA-8000 AL (UL) 23/MAR/15 10:22 3933 3817 4711
When I hard wired the compressor, I used appropriate size wire nuts and connected this wiring in the 2 gang box to the 10g THHN wiring and ran this to a compressor mounted disconnect switch and then from this disconnect to the pressure switch.
My question is regarding the aluminum/copper connection in the junction box. Is the wire nut appropriate for this connection and do I need to use some type of Naolox or anti seize pasted?
Thanks in advance for the help.
