moneyisflying
So, while finishing my barn (30'x50'), and getting my wood burning stove out there going that I use to heat the barn up. I get a bit of smoke on initial light up of the furnace. I have adequate draw, and honestly after the fire is lit, and there is "some" heat, the smoke goes right up the chimney as its supposed to. However, it does leave some smoke in the barn from the initial light up. I did insulate the barn and its sealed up pretty good. So far, opening the giant 18' garage style door is what I have been doing to ventilate the smoke out, but during winter this isn't really ideal as the smoke rises and the door only goes up so high. Plus, after I am finished with the barn, I would like to weld, and do other projects out there that I may also want ventilation for.
My question is, what ventilation fan should I get? I want something that will work well, but at the same time not let all my heat out when I am not using it either (I want something that seals up pretty good when its not used).
This is the unit I was looking at, but I don't really know much about them, or what would fit my needs.
https://www.amazon.com/dp/B000IJRD5S/?tag=atomicindus08-20
