Do you put dust covers over your machines
Robert Haas
I am now the proud owner of a big 5 axis Mill and it will be homed in my dusty, dirty glass shop.
I was thinking I would keep a dust cover on it, and wondered if this is a common thing? (Never seen my buddies do it):sad:
red94chev
Northeastern MD
In a glass shop? I would most likely cover it, or at least as best as you can. I would want to minimize any weird stuff getting into the machine/coolant.
57JoeFoMoPar
S. Plainfield, NJ
Generally, No. But I do keep a dust cover on my new HTP Invertig211, mainly because I don't want dust/paint/etc getting on the circuitry. Any machines that are less complex, no way.
larry_g
oregon
I split the shop and have the machine tools separated from the 'dirty' area. I have one big horz mill that I have thrown a sheet over in the dirty area. I found that the sheet held moisture and left rust spots where it was touching bare steel. So damned if you do and damned if you don't kinda thing. I would not want any machine tool around glass particles, they would grind the ways into oblivion very quick I think.
lg
no neat sig line
bob15
Northeasten, CT
How big is it? The 5-axis cnc machine's I've seen are a half million and up and are 10'+ long and 8'+ wide......
Mark in Indiana
Southern Indiana
Because of problems with flash rust in my part of the country, I keep cut sheets of cardboard on the machined surfaces of my table saw, scroll saw, drill press and sander. The vises (when not in use) get covered, first with cloth, then a plastic bag on top of the cloth.
22george
SW Ohio
I cover mine for condensation control and to keep dust off. I do sanding and grinding in my barn. Mark in Indiana, I like the idea of cardboard on the machine surfaces. I'm going to do it as well.
Mark in Indiana
Southern Indiana
22:
I also coat the machined surfaces with furniture paste wax. Not only helps prevent the flash rust, but also keeps the surface slick to slide the workpiece.
Mark in Indiana
Southern Indiana
All:
It's been my experience to put something between a plastic covering and the machine. Like a bed sheet. Otherwise, you may have a problem with condensation.
tarmy
Nor Cal
Buy one of the good large covers for full size table saw with extension table. They have magnets to hold them on...and will reduce the settlement of moisture on the ground surfaces that can rust.
I cover all my large tools to keep them from rusting, getting **** on them....and paint if I am painting up a welding project...
You can see the cover over my saw in this...
mikegt4
sw ohio
I had some rust problems in my non-climate controlled shop. I started covering my lathe with a HF "moving blanket" and that has seemed to solve the problem. They are cheap, usually around $5-6 for a 72" x 80" on sale or with a coupon. They also have them in a 40" x 72" size. I get the blue ones.
PelicanPines
My issues are... two garage cats... I used to get paw print rust spots.
My X Y table is fluid filmed and covered with oil rags and a plastic bag. Table saw and cast iron router table get cardboard AND hf moving blanket. The blanket holds the cardboard on.
My articulating drill press head gets a camping bag over it... mostly because I don't want it visible when my doors are open....
jonesg
northern Maine/
Worried about glass dust on a machine that generates metal dust and chips in its only purpose in life.?
I mean come on.
larry_g
oregon
I mean come on.
You sir are not a machinist. On a machine tool with ways the glass dust or any other abrasive will soon grind the ways so that the precision of the machine is gone. Normal cuttings are huge compared to abrasive dust that does all the damage. Good machinists and machine tools go to extremes to keep the ways clean and lubed.
lg
no neat sig line
Hexen
Texas
HF recently started offering a new free-with-purchase coupon for a new smaller size of moving blanket, too (40"x50" IIRC). I haven't managed to catch them in stock yet since apparently they've been very popular, flying off the shelves as soon as they get more in.
davewo
USA
What is a glass shop? We have a shop at work we call the glass shop, but it's for machining ceramics and other like materials. All the machines have some sort of dust suppression. If you do a lot of blasting, I'd put money into controlling the dust.
Lassen Forge
Yes, yes, and yes. Dirt, dust, and grit has a way to get into the bearings and drives, anything that is worth protecting needs a cover. Especially around abrasives (and glass is an abrasive)... you gotta do what you can to keep your new baby clean, otherwise you throw your accuracy out the window.
