Hugemoose
This is a stock photo off of google, but for reference sake, I have a similar type plug on my 30 gallon, vertical Eastwood compressor. (However the nut size is quite larger.) Photo below
I would like to drill and tap this for a 1/2" black iron pipe line to feed a regulator/air separator which would then supply the rest of my garage.
Right now it's just a small 1/4 pipe to the pressure switch and regulator. I'm trying to get the most out of this little compressor with high flow fittings everywhere I can, and just a 3/8" 50' hose after a small run of the pipe to where I have the spool. This seems like a good restriction to me.
And idea on what tap would work best for this? All I currently have is a cheap Advance Auto kit for smaller size stuff that I use on cars.
