I just bought a Fluke multimeter... When doing so, I was thinking about how ridiculous it is that I had to buy the thing when I have an iPhone in my pocket with the compu...
I like the innovation and it seems like it would have a lot of uses.
OTOH, there's something to be said for a tool that does one, or a few, things and does them well vs a universal tool that does a lot of things, maybe not all of them well.
You probably could rebuild an engine using a crescent wrench, but I'd still rather use a good socket set even if I can fit the crescent wrench in my pocket and carry it around everywhere I go. I sorta feel the same way about this device - I'd use it if I had to, but I'd rather use a real VOM.
They do! It's called "Fluke Connect"Man, I thought we had started a hot women thread again.
I have a Fluke that has a removable screen, would be cool if they could integrate that into an app.
I just bought a Fluke multimeter... When doing so, I was thinking about how ridiculous it is that I had to buy the thing when I have an iPhone in my pocket with the computi...
The reason you buy a fluke meter is for the a) accuracy and b) knowing the damn thing won’t blow up in your hand (accidentally ohming a live circuit). For the hobbist it seems cool, but for real work no way. I own a few flukes that will display the live values on an iPhone via Wifi. Nice to watch a circuit from a distance.
I noticed that there was no safety ratings on the Pokit device. That could be because of the low voltage range. If they decided to ramp it up to 120v or higher, then they'll need to completely redesign the thing.
CD
Nice having a stand-alone meter, I have 3 or 4. I can see the next generation loving an item like this unit.
I have some speed wrenches but I reach for my Craftsman open end wrenches first. Feels better to me.
Hoping someone comes up with a cable stripper for exterior 3 and 4 conductor cables that are now formed/poured around the 12 ga. wires. PIA to strip these when adding a receptacle or plug. Anyone have a solution, I would buy it!!
I suppose one could make the equivalent of a Fluke 233 where the remote display is replaced with a smartphone, but the electronics that converts live voltage, amperage, and ohms to digital isn't available in a smartphone (I think some phones can do ADC with a mic input, but it would be as much effort to convert every voltage you want to measure to something that input could handle as it would to just convert it to digital remotely). Also, you need to be able to switch between huge input impedance for measuring volts to no input impedance for measuring milliamps. I suppose the nice thing about using a phone for the meter display is that it could also incorporate a "how to use a dmm" tutorial.
How about the best of both worlds with the Fluke Connect system????
I just bought a Fluke multimeter... When doing so, I was thinking about how ridiculous it is that I had to buy the thing when I have an iPhone in my pocket with the computing power to walk circles around even the most expensive of multimeters. Wasted potential.
This dude, however, is working on that. I don’t think it’s there yet for a serious maker type, but I like the innovation.
Our install company uses thick extension cord for our 120V 1P grinding machines.
In the past it was simply (3) insulated conductors inside a rubber jacket, the conductors were all 12 ga.. Now, they make it buy pouring the jacket (vinyl) around the conductors. Very hard to strip when putting on the twist-lock ends.
I will post a pic when I get a chance.
