Using a car oil filter as a compressor air intake filter
metalmad
As subject
Anyone done this and any comments on flow?
I have a hobby compressor and replaced the sponge foam type element with a spin on type oil filter to hopefully improve filtration and intake flow, however I'm not sure on how well its sucking air in.,...
Shawn S
Brookings, SD
It's made to filter a fluid. I can't imagine it's going to filter much from the air. Seems like it will let most things pass through.
EOC_Jason
Bentonville, AR
^^^ Exactly... It's not going to be nearly as fine as an air filter...
Go on Amazon.com and search for "solberg"... Get one of those...
metalmad
Its a cheap hobby compressor, the filter it came with was a chintzy piece of plastic with a piece of what appeared to be dish cleaning sponge as an airfilter
Plus I'm in the UK, so a lot of the decent filter brands are sadly either not for sale or crazy money here...
Oddly I find the oil filter to flow less air than the OEM sponge filter, which shows the oem sponge isn't doing much in terms of filtering.
Compressor is going outside the shop in an insulated box to save my ears (its cheap,nasty and loud)
Gmonkee
If it isn't starving for air it will be ok. Those cheaper units are pretty flexible on the state of maintenance they will survive.
Most I seen in auto paint shops had no filter at all and sucked up all the dust. Anything is better than nothing.
inyoyote
Since oil filters are typically rated down to 10 microns, and they are known to reduce noise since they are used in home brew silencers, you may be on to something. I think you would need a pretty large filter to not create vacuum, at least 1” ID for the threaded bung. Oil filters are cheap and easy to change. This isn’t meant to be a replacement for a proper solberg, but it would definitely suffice for a basic home owner model. I have a cheapie air compressor that I may try this on for a little testing.
Thanks for the idea.
PBCampbell
WV
I'd think you'd trip the bypass valve and be pulling at least a significant amount of unfiltered air.
crewchief888
NW indiana
or you can do like i did, and toss on a hi-flow intake filter like i did to my compressor...
picked up massive amounts of HP and torque :rocker:
:lol_hitti
:beer:
firworks
IL
you need to rotate it up so it's good for water crossings too ;):D
I would strongly consider a lift kit at that point too.
As subject
Do you have a picture of what you've done? I'd be interested to see it.
rsanter
visalia ca
Interesting idea.
Someone has to be the first to try it and let up know so I nominate you.
I could see how it may be too restrictive and let air thought the bypass but I would think it would be easy enough then to use two oil filters
metalmad
I will try and get out to the garage in the next couple of days
Filter has a UNF fitting on it, compressor was 1/2 BSP (so ~19ish mm)
Bought an adapter from a hydraulics / pneumatics supplier
screwed the adapter into the compressor and the filter onto the adapter
mbshop
visalia ca
My little comp had a small, and I mean small, foam filter. It disintegrated and stuck one of the reed valves open. So after cleaning things up I was limited in space for the filter so I just used several layers of felt.
so far so good. If you are in a dusty are then get a good air filter for say dift bikes, etc. Even lawn mower, etc filters will do.
metalmad
Filter setup
compressor
1/2BSP male to 1/2BSP male
1/2 BSP female to UNF male hydraulic adapter
Oil filter from a gen 1 Yaris / Echo
(no idea why the photo has went upside down as its the right way up on the computer)
SirNik84
Sacramento CA
A long time ago I picked up an old Fiat air cleaner, I don't even remember why I had it. After having in for years I finally deiced to put it you use as the air filter for my hodge-podge air compressor.
