That tool you have no idea you needed
ezriderga
NW GA
If you’ve ever flushed the cooling system in your car you know what a mess it can be. I learned about this “tool” on another forum when I was replacing the heater core in my 1990 MX5 Roadster. I flushed the system 3 times before adding new coolant and never spilled a drop. Get this before your next coolant flush. You can thank me later.
https://www.amazon.com/dp/B00A6AS6LY/?tag=atomicindus08-20
bwringer
Indianapolis
1/4" drive roto ratchet. (AKA "Swivel Head")
The're made in Taiwan and you can get them at Harbor Freight, Menards, Napa or just about anywhere for under $15.
Holy ****, it's the handiest thing in the world. One of those "where have you been all my life?" realizations.
I have at least three where I just leave the socket mounted, since they're sizes I'll need on just about every project -- one with a 10mm deep, one with an 8mm, and one with a 12mm.
jchetty
Central New Jersey
Amazing tool but when did they start making them translucent:beer:
I guess I will give mine again and buy this. I gave away my last one to get the newer one with the lid:thumbup:
The Swanson (aluminum & magnetic) led-torpedo, bubble level is amazing. I did one of the adjustable closets in a dark room. It was up in no time.
Rico.
England
It was about 10 years ago for me when I bought my first air compressor
and a load of air tools... An impact wrench and a blow gun are the closest
thing to witchcraft if you've never used them before. :thumbup:
Honourable Mentions...
High Quality sockets, ratchets and wrenches
Brake Clean
All my other air tools
Decent workbench
Lots of good lighting
The Cobbler
well, 30 plus years ago it was a cordless drill
late 80's a finish nail gun and compressor
8 ish yrs ago, an oscillating tool
ok, maybe these weren't tools that I didn't know I needed, but more like, how the heck did I get along without them
larry4406
Northern Virginia
I’m not getting the $40 translucent funnel to fill a radiator.
Turn oval shaped coolant bottle so major axis is parallel to ground then gently raise bottom with opening at high point and pour away with no burps or puking of jug. Meanwhile use $40 to buy beverage of choice.
Roberts210
Missouri
I have a long list... air compressor, Lincoln AC/DC stick welder, angle grinder and probably some more I can't think of now.
M_George
Eastern Pa.
My set of GearWrench ratchet wrenches. They've made life easier several times over the last year. never gave them a thought over my regular combo wrenches until joining GJ.
vavet
Ashland, VA
Another vot for a battery powered impact driver. I always used my cordless driver as a driver for the screws, the impacter is so much better.
ambenz
NW Chicago Suburbs
Bought this tool this morning before the guests arrived for the big family get together!
Wouldn't you know it, my kitchen sink got plugged up!
Pistol Grip Drum Drain Auger
93cummins
Tape boss very handy tool I actually seen on you tube and picked some up as Christmas gifts for some friends and family this year
https://tapeboss.com/
Smallblock
Multi tool. Those oscillating bladed tools. Unbelievable!
I'll agree with that. Always thought it was just a stupid gimmick. I got one harbor freight a few weeks ago and its pretty damn handy. Now I want a good quality one.
Todd.Brock
Cincinnati
Astro Pneumatic digital tire inflator among others, but damn I if I don’t hate airing up the tires because I can use that thing. Next best thing would be Paslode cordless nail gun.
WVBrady
WV
It's real use is in burping your coolant system when you have drained/flushed the system. You just leave it on the radiator as the engine is running and it keeps the radiator full as the burps come up. I just kluged one up with a funnel and some duct tape.
ssdave
Eastern Oregon
1/4" insert bit ratchet. Got a mac MR5bd, liked it so much I bought a kit and converted one of my Snap-on flex ratchets to bit driver instead. Amazingly good for use on torx bolts.
Two Door
Houston, TX - USA
Oscillating tool and a reciprocating saw. Because there are situations you can't foresee for which they are the perfect answer. Again and again.
BeachBoy
Impact screwdriver
Finger/gimball ratchet
Countersink tool
MushCreek
Upstate South Carolina
I'll add to the oscillating tool group. Most tools I can see the use of, but this one surprised me. I got a Makita, and use it for all sorts of things. Oddly enough, I rarely use it for sanding, which is what I think they started out as. My Milwaukee M18 tools continue to amaze me. I built an entire house with them, and more recently added a 1/2" impact. It's a game-changer for me.
Tonyuk
Scotland
Set of thin double open end spanners, inspection mirror, head torch, electric impacts, really long extensions, loads of those magnetic pick up tools, wire wheel drill attachments, portable pressure brake bleeder. Few others probably but those have been extremely helpful over the years and aren't stuff you think about starting out.
marius_nortje
Framing nailgun.got a 28* from northern tool few years back maybe use it 4 times but sure make things go faster
Sent from my LGLS990 using Tapatalk
LeeG
Phoenix, AZ
Knipex Pliers Wrench. I have one of the small 125mm ones that is very handy around the shop for use on all of the different metric/SAE nuts and bolts.
