Foam pad for cutting
camardelle
Willis, just north of Houston
Looking in big box websites for this and I have no idea what it’s called or what to search for.
I want to break down some plywood and see guys cutting on some kind of foam (maybe?) piece they put under the sheet of wood.
What the heck is that?
K'ledgeBldr
Johns Creek, GA
That's a mighty expensive saw horse!
You could buy two saw horses from HF for that amount and get CHANGE. And they'll last a whole lot longer!
C
camardelle
True, but then I wouldn’t be as cool as the guys on TV.
Big fan of HF, but their sawhorses were a terrible investment for me. I’m wondering if I should invest in a set of brackets and make some sawhorses. They’ll be sacrificial ones as I won’t keep them indoors.
Actually I may have some metal ones out back. [emoji33]
PWC Repair
Arkansas
Sometimes you need to cut sheet goods in half. Without 2 sets of sawhorses or a helper you'll get a snapped corner and half your sheet falling off onto the ground. I've been known to cut in between a couple pallets on several occasions.
Hubmonkey
OK
Also need to consider there is less tear-out with the cut being supported by the foam.....
Hub
EVOLVO
Port Hadlock, Wa
Using a foam underlay is also a good way to cut sheet metal if you don't have a band saw. If you use the jig saw lay the sheet metal on the foam and get to cutting. No more vibration trying to cut metal hanging over the edge of your workbench. Works like a champ!
ScottsGT
Lake Wateree, SC
That’s it! Thanks a bunch bud!!
I use the same thing and experienced an unexpected issue. I store my foam sheets cut into 2X4 sections so I can use smaller pieces if needed, or as much as needed. Problem is, they warp over time standing on end.
I used them the other day to cut some circles from Masonite board and the Masonite wasn't heavy enough to flatten out the warp. Cutting depth of the router varied with the warp.
