Floor jack storage
D45
NW INDIANA
I have two floor jacks......trying to solve the problem with them taking up too much floor space
I was thinking about taking off the handles, and sliding both under the work bench
Any other clever ideas?
PoorOwner
CA
Handles off and slide them under shelves or on shelves. Some will fit under tool boxes with 6” casters
EOC_Jason
Bentonville, AR
I've seen some pics where people make brackets and store them vertically. Personally I think it would be easier to remove the handle and slide it under something else.
NUTTSGT
Northern Central Ohio
I set mine in front of my press.It fits nicely between the horizontal floor braces.
If you rarely use your floor jack, you could buy a Pit Pal (or similar) floor jack holder and mount it to the wall.
fourjeepin
Atlanta, GA
I leave one of mine under the front of the Jeep. Not a good option for low ground clearance vehicles though.
rburke65
Canfield, Ohio
I have one in the barn that is stored under asset of metal shelving. I just raised the bottom shelf up about 8" above the floor and I leave on the handle.
ford33
Chicago, IL. USA
I store my jack vertically on a wall. When ready to store the jack I position it near the wall mount and remove the handle. A strong stiff wire is always attached to the front of the jack near the front wheels and forms a loop that doesn't flop around. A strong hook is attached to the wall about 24" above the floor. I lift the jack near the front wheels, the stiff wire maintains its shape and position and I hang the wire over the hook. The jack is off the floor and out of the way. Jack handle is also hung from the wall.
I found that if I use a flexible wire or cable it moves around as I try to hang the jack making it difficult to get it hung on the hook. The wire used is about .125 dia and intended for wire fence repair. I have a 3 ton jack.
bad_idea
Pasquotank, NC
One more vote for handle pulled and slid under a bench. I have a wing nut on the bolt for the handle attachment. Have a hook on the wall for the jack handle storage. There is no way in hell I'm hoisting that heavy ******* onto a shelf.
Lelandwelds
Central Texas
I had two 55 gal drums close together. One had oily sand to clean tools. Other was full of shovels. Jack rolled between them.
peterl
I leave mine out where when my wife pull into the garage the jack goes under her truck and with the handle sticking up where she can see it when the bumper touches the jack handle. when it moves she is in the garage far enough. Marked the floor where it sits.
good luck
Peterl
crewchief888
NW indiana
mine stays on the floor in whatever empty spot i can find....
usually slid under the work stand for my abrasive chop saw....
mines an old heavy nesco hydraulics 2 1/4 T ive had since the late 80's
:beer:
apollo11
State Of Reality
I have 4
I leave the handles on and roll them under a shelf
Sure the handles block a couple shelves but I just lower the handles when I need to access the other shelves to pull a milk crate full of stuff out.
I just planned what crates I put there accordingly.
metalmagpie
Seattle
Under the workbench next to my chain saw and portaband in its toolbox. Handle stands in a nearby corner.
D
D45
NW INDIANA
I like the idea of a wall mount, but not a fan of lifting it up there........too old for that
I will try removing the handles and storing them under the work bench and see how that goes
Lelandwelds
Central Texas
good luck
Peterl
Any other examples of your genius at work? Because this is some excellent multitasking!
lakeroadster
Central Colorado
I'm fortunate to have enough space to just park my long frame floor jack beside our barn loft stairway.
The little 2 ton short frame jack occupies a space at the end of the floor cabinets, along with wheel chocks.
D
D45
NW INDIANA
I tried it, and don't like it under the bench........
I am just going to built a shelf that both floor jacks slide under and then I will put my 50 gallon garbage can ontop of the shelf
It will save some space, basically the size of the square based garbage can
6PTsocket
The floor jack just gets pushed around but I bought a tractor lift and that was one jack too many. In the ad for the lift they showed it hanging from A Gladiator Gear Rail which the did not mention by name. The thing weighs about 65 lbs and was dubious whether it would hold . I got a couple if sections and the big hooks at Lowes and it really does hold it well. I don't think I would try it with my 2 ton Hein Werner but it might be good for a lighter jack. It also leaves room to hang some other stuff.
ezover
3rd rock from the sun
I store mine right where I am going to trip over it at some point.
I have it pushed under a cabinet, I will be looking at removing the handle since it is rarely used. duh. never thought of taking the handle off lol.
D
D45
NW INDIANA
In under 30 minutes, to built this contraption
I had all the scrap wood around the shop
It works and works well, saves me a 2'x2' area since the garbage can is now sitting ontop of the jacks
andy-gts
I would flip the base around so the handles would be to the left side out of the way.....but clever idea for space saving
gtsgarage
California
Awesome thread. Never thought of taking the handle off. In my old garage I had a great alcove I could hide it in. Just moved a month ago and it’s been mostly in my way.
PugetDude
Superstition Mountains, AZ
I park mine under my 6x 48 belt/9" disc sander. The handle stands vertically and tucks in behind the disc. Takes up ZERO floor space, is always ready to use, and I don't have to remove/replace the handle every time I want to use it.
