olds70supreme
- Joined
- Mar 7, 2008
- Messages
- 695
I need help troubleshooting a Heat N Glo gas fireplace. When either the manual switch at the fireplace, or the thermostat are turned on, the pilot lights. You can see a small blue flame in the rear and an electric ignitor runs the entire time. This goes on for maybe 30 seconds, than the pilot turns off. This started happening intermittently, now it won’t light off at all.
When I pull off the control panel I can see the valve behind it., but only a single wire to each of the pilot and main valves. Every troubleshooting guide I can find shows more connections where you can jumper the valve to rule it out as the culprit. There aren’t any more connections on the rear or sides, I checked. Anybody know more about these than I do?
Pics show control panel, gas valve, and a terminal block. Fireplace model is 6000TRXI-IPI, manual was not much help.
