At this point I'm just trying to scope out the possibilities so any input is appreciated.
At my parents house they have trouble with uneven heating. This has been a problem since the house was finished about 10 years ago. The trouble always is that the temperature in the old section of the house is not consistent. The thermostat is in the new section of the house. Air conditioning is the summer does not seem to be as problematic.
A little back ground, The original 26x26 section of the house was gutted and all new mechanicals were installed at the time. The addition was a small 26x50 ranch style house was moved and attached to the old house. It ended up being a pretty big house but it was cheaper than building an addition. The ranch style house was about 10 years old when we moved it and not a lot was changed in it at the time. A new heat pump was installed to serve the whole house. The duct work in the old section is all new and the duct work in the new section is a mix of existing and new.
We have experimented with adjusting registers to no avail. If there is a strong wind from the east it will make that half of the house cold. If the wind is out of the west or north then the old portion of the house gets too warm. There are some large windows but the house is well insulated and not drafty.
The air handler is stamped '08 so not that old. The unit has a variable speed blower and I think the heat pump is 2 stage. It's a Trane 2tee3c65a1000, it's a air-air heat pump with I think 25kw of electric coils . It uses a communicating thermostat. It was sized and installed when the house was redone.
I just want a solution that gives them fairly consistent temps throughout the house. The idea of zoning came to mind since it is a pretty large area to control. I'm not how that would work since the system is already installed. Any other solutions would be greatly appreciated though.
Anybody have experience with that sort of thing? I'm not totally clueless but I know little to nothing about zoning.
