Old Saylor-Beall compressor
Garagetime
New Hampshire
I got this old compressor a few years ago. When I got it I did not really look at it till today. I had to go looking for a belt for my drill press. I knew it had a belt on it turned out wrong belt. Anyway I got looking at it and what a cool old compressor. I thought I would share some pics of it with all of you. If any of you have any information on it that would be cool. If not still a cool old compressor. It dose pump air and it has a newer motor on it. The model is 930-K the tank I believe is cast iron.
redmondjp
Redmond, WA
Thanks for sharing those pictures! If you really want to go full retro on this unit, try to find an older electric motor that is age-appropriate for the unit.
G
Garagetime
New Hampshire
It's just a cool old compressor that probably only pumps up to 40 maybe 50 psi. I would have no problem using it to put air in tires. I feel there is more of a risk running some 20 to 40 + year old 2 stage compressor that runs at 150 to 175 psi. That I'm sure some never even looked in or checked the tanks and put them right in use.I looked at a lot of used 2 stage compressors. I would not charge one of them. I looked at to 50 psi nevermind 175 psi.
