acetylene leak
ichabod
minnesota
walked into the garage this morning and thought I smelled acetylene. checked the tank, empty. the tanks were shut down proper, both the oxygen and acetylene tank valves were shut tight, regulators were backed out and torch was off. last time I used it was last spring. when I put it away then I knew the acetylene was very low. I have had this set up for years and never had an issue like this. We have had some cool weather past couple of weeks, well below zero. but that's normal here. the tank visually looks good. any ideas on this. glad I dint have a full tank........
SgtHawkUSMC
US
Moisture froze in the shut off valve? Seal went bad? Could be any number of reasons, but if you had the main valve shut off and it leaked, that's the first thing that would go if it were mine.
BDT/NWMN
Erskine, Mn
If You have exchange tanks, mention the potential problem of a leaky tank shutoff valve.
They ""might/may" compensate your loss with a full exchange tank at no charge..
I own all My tanks, but carry ten year test/exchange/service contract/agreements on them.
Worth asking The vendor.
Kaizen
New England
Thought acetylene was not smellible? What does it smell like? My little tank scares the hell out of me
BDT/NWMN
Erskine, Mn
It is hard to describe; other than it smells like acetylene:eek:
It is a smell I relate to lighting a torch.. So the only other thing I can say it smells like a torch being lit :confused:
MO-Iron
SW Missouri
If I remember correctly, most acetylene tanks have a fuse plug in the bottom for explosion prevention in a fire. I have not had one leak, but that is a possibility.
fordkid88
Is there something particular about acetylene that scares you or just the tanks in general. I'm not super big on the oxy/acetylene setup and rarely use mine so I traded my big tanks in for argon tanks for tig welding.
Kaizen
New England
More like a lot of respect...boardering on fear. Not a lot of time on the torch I guess. I know that little tank has enough explosive power to level my shop so I make double sure I close it up. The cylinder connections arbitrarily shooting out the regulator pin things and killing you also freaks me out
fordkid88
I have to agree with you. I have the greatest amount of respect for those tanks and tablesaws, or fear, fear or respect not sure
fordkid88
How old were the tanks? 5,10,15 years of cold cycles could have done damage. Regardless its time replace that tank. No issues with the oxygen tank?
Kaizen
New England
Google "plumbers van explosion", supposedly a "B" acetylene tank leaked and the keyless entry system sparked and detonated the van.
The same summer I got my little torch a car in a parking lot disintegrated from the exact victor jr being stored in the trunk and a shop with a larger tank leaked and ignited. I know it is heavier then air and don’t think it dispersed easily. Now with op saying even if you do all proper steps it still can leak. Oy
Buckgnarly
VT
Acetylene is lighter than air.....
http://www.esabna.com/euweb/oxy_handbook/589oxy1_13.htm
I
ichabod
minnesota
looked the tank over good, could not find anything. oxy tank still has pressure. I have had the tanks for 8 years, they were my fathers before that. I don't use them much, except for warming up stuck nuts/bolts and some cutting. the smell is gone today. I will replace tank when I bring them in.
thanks
fordkid88
As for the smell of acetylene, don't they mix in acetone that's why you have to let the tank sit for a day after transport, so it does have a hint of acetone.
wiens80
Freaky thing about acetylene is its limits of flammability. From 2.5% - 81%.
