What's it? Ford stamped thingy jigger
72highboy
So Cal
Hey all,
Cleaning out the gramps garage, found this something or other, anybody have any ideas?
Looks and feels like forged steel, and is slightly magnetized, enough to pick up adjacent fork.
Sent from my Nexus 6P using Tapatalk
ihateminimumwage
Check this out! Looks like it might be part of a Model T flywheel.
http://www.desert-vehicles.org/index.php?article_id=223
Googling "Ford v shaped magnet" pulled up some info.
I'd say we have a winner!
index.php
This is the flywheel/magnet combination and also shows the four bolts which secure this to the crankshaft once the gap is achieved.
2000-cvpi
It's a cool sentimental piece. Drill holes on each end, put key rings in the holes and use it as a keychain.
Lassen Forge
It's a magnet of a flywheel magneto off a Model T. They will recharge; being Model-T-aholic, I have a couple dozen of them... they make AWESOME magnets.
Side nonsense - there were 16 of them bolted to a Model T flywheel. They passed over stationary field coils to generate AC current to (1) energize the ignition coils (1 per cylinder), and (2) generate the electricity (starting in 1915) to run the headlights and make the horn beep. The coils were specifically designed to take advantage of the AC current, and when set up right, would throw a MASSIVE spark 3 times per compression stroke.
The upside - you did not need a battery to run your car... crank it to start, and off you go.
72highboy
So Cal
Cool! Thanks guys..I know I could just Google but this is fun and figured other people haven't seen it before either. Definitely a keepsake for me..Lassen, have you recharged them before?
gdocktor3
Connecticut
Awesome :beer:
6PTsocket
And I thought individual coils per cylinder were something new. We seem to go round and round, CVS transmissions were around in the 1890s and a Dutch 3 banger called the DAF had one in 1958. What other great modern innovations are just reinventing the wheel?
