How is this tool not better know by every one???
WILD-BILL
Brook Park Oh
When I worked in the auto center at sears a guy I worked with there had one of these spark plug installers that just flat out made any plug change a breeze. All the markings were wore off and he couldn't remember where he got it from so after I left there I had been on the hunt for one of my own.
Seems all my searches came up empty and no I talked to had any idea of what I was referring to.
But now, after 3 yrs of hunting the right combination of words were dropped into Google and victory was mine.
This handy little thing is such a life saver I ordered 3. One for work, home, and my race car trailer.
https://www.amazon.com/dp/B000IE5TSQ/?tag=atomicindus08-20
If you happen to have one you can atest to how usefull iit is.
If you don't have one and do even the occasional spark plug change, I guarantee you wont be sorry for getting one. :beer:
signcrafter
These are so much nicer then a hose. Until you use one you will have no idea how nice they are. Sure if all you work on is older cars with lots of room in the engine bay then a hose is great. But if you're working on the back plugs of a transverse engine by the firewall in a cramped engine bay then you will see how nice this 10 bucks tool can make your life.
https://www.garagejournal.com/forum/showthread.php?t=319373&highlight=Spark+plug
454ragtop
Carver, MA
Rlfd213
I have had the same one and use it regularly for the last 20+ years. It is really worth the couple bucks it costs.
lugnut71
Wyoming
I have a blow gun made from the same stuff, works awesome to blow around hard to reach plugs
B.S.A. (ret.)
Central Connecticut
A similar product has been in use for over 40 years to direct coolant on to metal cutting tools used in the machining industry. Never seen it used in this application. Spend a little time here, learn a whole lot!
davethorik
Norka, Ohio
Yes Loc-Line! Pretty good stuff. I think someone posted a Worx electric screwdriver the other day on here and it came with a flexible extension with these on the exterior.
Fedwrench
Valley of the sun
Knew of this model and the probably more popular one from Thexton. Never felt a need for either one.
I've always used a knurled spark plug socket of varying length to start spark plugs :dunno::wtf:
I still don't think I'm missing out on anything. Good thing most of the vehicles I service have iridium plugs that last 100K miles or so:lol::beer:
Gmonkee
Didn't know a tool was made but have used the hose trick a long time.
I learned it from a guy 50 years my senior at the time.
signcrafter
Snap loc line, very common in the machining world. Never thought of it for this use....
While they are similar this tool is a lot more then snap loc line. The loc line bends to whatever shape you need. The end has a foam like insert that holds the spark plug, but if it starts to thread wrong the plug will spin in the foam so not causing any damage. Then you just twist the other end, there is some kind of cable or linkage inside from end to end. But the outside doesn't spin.
So if you're doing back plugs on an engine you can basically bend it in a U shape. Stick it with a plug in the hole and twist the knob and it threads the plug. Unlike with a hose the whole thing spins and flops and doesn't hold the same shape. It's hard to explain and until you use one you won't appreciate it.
If I get some time I will try to take some pics of mine in use. Or even a video if I get time.
Qualitytools
SOCAL
Thanks for sharing, I will have to get one as I just replaced my spark plugs and as always some are more difficult to reach than others.
