zmotorsports
started doing the upper part of my walls.
That is turning out awesome.
How many pallets is that?
Started taking things apart for adding turbo power!
Put up a little more wood on the walls.
New age cabnets delivered and unpacked today. 2 cabinets coming on another shipment. These cabinets are really well but and came without any damage. The one corner cabinet I need to start installing these didn’t make it, so all I can do is wait.
My overhead cabinets also arrived on the 8th and I installed them that evening.
First real use of my garage. Put the tracks back on for the winter season. Bring on the snow!
What products and tools did you utilize? Professional appearance
Not my garage, the school's. Yesterday was the FIRST Robotics Competition kick-off so the team received the new challenge and I picked up the kit of parts with a student. Then, with a couple of other kits I did inventory of the parts received, we learned a bit about nomenclature and we even had to do some technical translations. Oh ya, we ate pizza....again![]()
Did a headlight restoration for a friend of mine.
Thanks. It’s a process. I first pre clean the headlights and mask off the edge of the lens to protect the paint and any chrome trim. I then wet sand using different grades of sandpaper depending on the lens I’m working on at the time. On these I used 1500 and 3000. Next I use a polishing machine and pad along with Meguiars compound and then polish. After cleaning off all polish residue, I apply a protective coating. This job took approximately 1 1/2 hours.
Assembled the paint booth in my garage in prep for painting my project bike tomorrow. Adding the plastic, taping it to the frame and itself, sealed it well, and made the frame stiff.
Still a little more to do.
The two fans, one pushing one pulling, create a small air flow that should help. No worries on the fumes, I have the right gear, and the paint is low VOC.
