arctic builder
So, as I did told in the introduce yourself-section, my garage project which has been long time on hold is picking up some speed in the next few weeks.
The specs of the garage are :
Foundation measurements are 8 m x 12 m, garage section will be in inside 7.5 m long x 9.5 m wide x 3.6 m high.
Storage section will be 5.5 m long x 2 m wide x 2.3 m high, also the storage section will contain 1.8-1.9 m long x 2 m wide WC.
The frame will be made in out of 48 x 125 mm timber and additional 48 x 48 mm cross frame, total rock wool insulated wall thickness will be 175 mm. The roof will be insulated with 500 mm of rock wool. In the floor will be 150 mm of styrofoam and 100 mm reinforced concrete with extra reinforcements for the 2-post lift (s).
The outside will be painted board upholstery (of course because I live in finland which is a country that is basically one big forest and my house has the same kind upholstery
). The roof will be made in concrete roof tiles, also same kind that is in the house.
It will be a warm garage with storage attic and running water, oil and sand separation sewer, fire alarm, burglar alarm, fixed compressor and air lines, antenna and network capabilities. Also at some point, when I start to stop being poor and start to get richer, I will get there a 2-post lift.
here are some pics from the lot and the frame waiting foundations.
). The roof will be made in concrete roof tiles, also same kind that is in the house.It will be a warm garage with storage attic and running water, oil and sand separation sewer, fire alarm, burglar alarm, fixed compressor and air lines, antenna and network capabilities. Also at some point, when I start to stop being poor and start to get richer, I will get there a 2-post lift.
. But when it is started, it have to make finish.
, if I would be doing the frame build with friends and relatives after work and weekends, it would not be ready ever.
. I will try to post updates accordingly to progress.
. I know, I am a lazy mother f#cker
