rick carpenter
I've searched and this has been covered before, but no real resolution. Plus there are new products out since the last go 'round. I have a Lenox hole saw set with two 3/8" shank arbors. One is for smaller dia saws, just plain screw-on against the fixed collar. With just a visual, the bit is not centered in the hole saw. So... wobble! The second arbor is for the larger saws, screw-on with sliding spring-loaded pin collar. The saw does not fit tightly to the larger arbor and wobbles but the drill bit doesn't, it does acceptable in use on wood. I also have two Fastcap Quick Mandrels with 7/16" shank arbors. The first one's bit wobbled, so I called for a replacement and the second one wobbles as well but the saw does not wobble in when locked into place. The drill bits have three flats however the set screws set against a small flat ground into one of the triangular edges. The bit fits loosely into the triangular housing to begin with so no wonder it wobbles with just friction holding it in place. Simply putting the set screw against one of the triangular flats and having the other two accurately locate it would have solved that issue. But then any generic three-flat bit of the correct dia could substitute in and Fastcap seems like they like to keep things proprietary.
On the other hand HD has a Milwaukee listing as "7/16 in. Quick Change Large Hole Saw Arbor with No Wobble" #49-56-9100
https://tinyurl.com/yaxuo6lc
It is only in 7/16 in shank tho. It has a locking nut under the pin collar and the drill bit looks to be set-screwed into place so if that is accurately located it may indeed be no wobble. Milwaukee does not advertise "No Wobble" but I'm hopeful.
And Spyder has a "1/2 in Hex 10 High Speed Steel Hole Saw Arbor - For Wood, Plastic, Metal" #600634
https://tinyurl.com/yarmjky4
The drill bit is fixed to their shanks (they also have 3/8 in systems), but the pin collar looks like it spring-loads to the saw. So while the bit may not wobble, the saw likely will. But then, it may do acceptable in use like the large shank Lenox arbor.
Anyone have any thoughts? (The Fastcaps are going back for sure.)
