Ceiling or No Ceiling
haneyrm
Placida, FL and Ellijay, GA
I'm having a new 30'x30' concrete block garage built at my place in SW Florida. The builder has asked if I want a drywall ceiling or if I want to keep it open. The roof structure is attic style wood trusses. The cost to add drywall to the ceiling is $1,000.
I can't decide if a ceiling makes sense or not for this garage.
Any pros or cons to help with this seemingly simple decision?
Thanks!
buildyourown
I would. A clean white ceiling will make your space more comfortable, cleaner, and have better light.
ItsNemo
Canada
I would...vapor barrier then drywall...so that it can be insulated with blown in.
JamesW84
Springfield, MO
I think this depends on if he will have attic ventilation or spray foam the roof. If he as attic ventilation, I've been reading that a vapor barrier is not recommended for the ceiling so that the warm, moist air can travel up to the attic and out via ventilation.
matt_i
SE Michigan
I would install the drywall. In hot summer I've been able to feel the radiance on my face in a few open-attic buildings that I've been in. I think the additional layer of building materials would help cut that down.
Also, assuming you want to heat and cool you have less "cube" (cubic volume of air) to process.
Justind97
Ottawa, Canada
Are you physically able/have time to do it yourself?
You’d be in it for about $325 in materials if you did it yourself excluding any mud
H
haneyrm
Thanks for the responses. I have no plans to ever condition the garage. The roof is shingle over plywood. The plywood includes a radiant barrier on the underside. The attic trusses will have a plywood floor for storage. No other room or anything above.
Thanks again. I'll probably go ahead and just have him install the drywall. I can do it but 5/8" drywall overhead is not something I'm really interested in messing with. The $1,000 doesn't include painting. It's an additional $1,300 to fully paint the interior of the garage including the ceiling. I'm already having him epoxy the floor so might as well go all the way and get it completely done.
JonBoehman
Philpot, Ky
I personally would do the ceiling. As for paint do it yourself in white. It is way to easy to do yourself for less than $100. You will appreciated the help with lighting it will do. Install a attic ladder at one end for attic access
