2018 Lowe's deals/sales/clearance thread
dh1
Besides the utilitech being reduced there are some sylvania T8 LEDs that were being clearanced out, at least at my store... Lots and lots of them, ~$5 each IIRC....
Same here, they moved the bulk of the bulbs where the Christmas stuff was with a giant clearance sign.
erty67
Alot of these deals are priced higher in store than online so it only makes sense to buy online.
I've never seen a mismatch. If it's marked down online, it rings up that price in store. I have benefited from the shelf tag being outdated with a higher price, but rings up same as online every time.
EOC_Jason
Bentonville, AR
Same here... I've never seen an online price lower for a particular store than what it rang up as *in* the store...
DanielC99
Central Arkansas
Probably locally specific in Conway, AR. Kohler bath doors marked down from $324 - $519 to $50. Pretty sure the last one that is still marked at $250 is supposed to be $50.
This store has all kinds of stuff in clearance. I found that the manager will knock off even more than what is marked if you just ask. Case in point, the 10 packs of Sylvania 4 ft T8 LED bulbs I bought a few days ago. Marked as clearance at $76.48. He sold them to me at $30. Item# 852837, Model# 75425.
EOC_Jason
Bentonville, AR
Yeah usually in the back wall area of the lumber / windows / doors they have a section like that with marked down doors & windows, I'm guessing cancelled orders or returns.
Awesome price on those LED T8's... If I didn't have like 40 regular spare bulbs I would probably consider upgrade but as-is I'm set for a while.. lol.
In The Doghouse
South of Due West, West of NinetySix in SC
Saw 16 ea pack of 4ft LED tubes for $67.98. Add to that a coupon and they get even cheaper. Which is better for a workshop with 9ft ceilings? Bright white or daylight?
https://www.lowes.com/pd/Utilitech-...right-White-T8-LED-Tube-Light-Bulb/1000264765
https://www.lowes.com/pd/Utilitech-16-Pack-32W-Equivalent-Daylight-T8-LED-Tube-Light-Bulb/1000264771
My local store now has these for $39.99 each and won't match the $18 each receipt posted earlier here. I need two boxes. Does anyone have a source for a $15 off $75 coupon?
Which is the better choice for a 9ft ceiling shop? Daylight or Bright Light?
Thanks,
Andrew
RRich
Horsham, Pa-Orange City, Fl
Just bought the Utilitech 778114 and am really disappointed. I tried them in two different fixtures and the light output was much less than the florescents. Returning them tomorrow.
DanielC99
Central Arkansas
Wow. Evidently the Sylvania LEDs are quite a bit better than the Utilitech's. I replaced 20 of the 32 bulbs in my shop and can see no difference in the amount of light put out. I'll have to move a car and some other stuff to get to the last 12 bulbs.
I have a brother that will use the fluorescent bulbs that I am replacing.
unslow1
Illinois
I'm glad I didn't buy them. Sorry you to had to be the one to try them out but now we know.
superskaterxes
Maryland
Thanks,
Andrew
the summerlin lowes has these for $40 if anyone is looking for them online.
89128 SUMMERLIN, NV
red
Hudson Valley, NY
Big question is your ballast electronic?
Someone else had issues with their ballast not being electronic and not working properly.
I installed my Utilitech 778114 and think their better, than the florescents .
(Did have to reverse one bulb cause they are directional, there's a top & a bottom)
Thirdyfivepickup
Portage, Indiana
padow12
Order some rulers post a couple pages back canceled without a call or email so slightly annoying
RRich
I don't know what type ballast. House is 11yrs old if that means anything. Ballasts have a slight buzz which didn't change when I tried the LEDs.
soob
The xxx114 utilitech bulb requires a ballast, though, right?
Only the xxx115 is "hybrid" and works without it.
In The Doghouse
So I got 32 of the T8 LED Daylight bulbs for $67 out the door. I would rather have the type that do not require the ballast but like this price for now. Maybe in a few more years the opportunity will present itself to upgrade again.
Will these T8 type bulbs work in the older T12 fixture with ballast? Most of mine are T8 but I still have a pair of T12 lamps I would like to upgrade.
06 DIESEL
Middle River, MD
i know its been a while but has anyone found this grinder on deep discount at a store that will ship? I know it was posted at the end of the 2017 thread but i havent been able to find anything since.
https://www.lowes.com/pd/Hitachi-4-1-2-in-12-Amp-Sliding-Switch-Corded-Angle-Grinder/1000144615
They have a 7" 15 amp for 83.30 once added to cart.
https://www.lowes.com/pd/Hitachi-7-in-15-Amp-Trigger-Switch-Corded-Angle-Grinder/1000142957
I also know that white marsh lowe's last week had several of the 4.5" 8 amp grinders for 49ish, I picked up one, there was two left on the shelf.
In The Doghouse
Yesterday evening I installed these into two of my 4-bulb fixtures. They are brighter with more uniform lighting than the fluorescents. For $2.12/bulb I'm a happy guy. I have four more fixtures to load up then will see if they will work in some 2-bulb fixtures.
:rocker:
SteedaGT
:rocker:
Great to hear! I haven't been able to install mine yet.
AP514
Pearland, Tx
I saw some conversion kits to go from T12 96" to T8-48" LED direct lighting for $8
loranger
DFW, TX
Robin B
San Diego, CA
I just picked one up in Irving TX today for $66. Theres one left if you can get it shipped.
Low is 13 in Ware MA. 20 in N Little Rock. 66 in Hagerstown MD, lowest in MD ( somewhere near Superskater) that I saw. Cheapest shipper is 71 from Missoula.
Sent from my Nexus 6P using Tapatalk
73fxe
SW. Michigan
When did Lowes start doing a 11% rebate? The last 2 days I've spent around 200$ in the Lowes in Anderson In. on the receipt it said it had a 11% online rebate.
Sh40674
Iowa
a store near me dropped the utilitech daylight bulbs to 39.99 with over 20 packs in stock... even with my previous comments this is now very tempting from being 68 bucks a few days ago.
any risk with ordering these online and having them cancelled? would go nicely with a coupon if i could..
