Great stuff as usual Randy! So glad you caught the melanoma early...take care.
Did you sell Eco 1 to make $$ or to be able to build an improved Eco 2?
What will be different with Eco 2?
I enjoy your thread.
As a lifelong Minnesotan, I am very jealous and amazed by the quality iron you have in non salt/rust states. 7 year old vehicles don't look that clean here.
TW...you sound alot more upbeat now despite your new medical stuff. maybe selling the truck and the infusion of funds was what you needed !!!i hope you can see those big expensive brakes through the new rims . i have a tacoma with big drilled and slotted on front and back.i get more compliments on the brakes than anything else ive done but the front warp pretty fast. mine are from rotora and hope you have better luck...but they still look cool as ****!!!! stay well and enjoy this.
I really enjoy this thread, glad your doing better and back in the shop, keep up the awesome progress !
I have never see one piece park brake shoes before, that's very interesting. I see that by doing that, it sure eliminates a lot of hardware!![]()
Silverado's have had that style park brake since '99
3 ounces every week of this nasty fluid collected from the passenger side PVC......imagine all this **** getting ingested in to the motor nonstop, if I didn't have a catch can
I also go through Iridium spark plugs every 20,000 miles and get 13 MPG!!!
I think that the problem was corrected by 2015ish, when they started using DIRECT and PORT injection in the 3.5L Ecoboost
427 Truck:
Part of dream of this truck was to run a Gear Vendors O.D. And to think i was close to parting it out a few months back thinking I would never finish it!
Holy ****!! Yes, that would really get old having to empty that each week. So I assume when you pull the dipstick, the oil in the pan looks normal? Now I'm wondering if you have blow-by, to cause that.
That's nuts, you would think Ford would have fixed this issue by now.Oil level is NEVER low...........change it religiously at 6,000 miles with full synthetic
Intercooler condensation and buildup in the PVC lines (both driver side and pass side) are a norm for all 3.5Ls from 2011-2015 (and even newer)
Have you ever taken the pipes/tubes off the intercooler and looked inside? They will be coated with this mocha mess
The oil in the motor does not get contaminated or used.......its the intercooler and the change of temps in the air, coupled with the PVC lines in this truck.
Most, if not ALL Ecoboosts have this issue
This thread is getting derailed for some reason , perhaps start an ecoboost discussion thread for this other stuff
Perhaps just simply ask the owner of the thread before we get all PC about it and start removing words. It is after all his thread and his build. I originally thought this topic could be more good information that affects engine swaps like TW is doing. Marrying old tech to new tech has all it's own issues as we've seen on these pages. TW has engineered his way around them all quite well.
So how about it TW, have you ever experienced an oil issue like described? Could it be affected by cooler placement and oil lines especially as you may have made adjustments in your 1966 engine swap project?
Do you think your thread got hi-jacked?
True, sorry about that. If a Mod would like to remove our Ecoboost chatter, I am okay with that.
The owner has actually pointedly asked why this was put into his thread, and for it to take place elsewhere.
Will be keen to see just how that overdrive unit works for you.
Wow! you have been busy. I like the factory 8 lug wheels your using, there is a lot of factory truck wheels these days that look nice and I prefer over aftermarket. Just curious on 427 truck why u chose a smaller bolt pattern for wheels ?
Just how I like em'! Just one of my extra cabs needs a bit of floor pan work. Anything more than that and I simply pass.WOW!!!
That is a clean and rust free cab.
Nice.
Looking forward to completion of the 427 truck.
It's a shame how so many of these trucks get a big hole cut in the dash to fit a different radio - plus, the holes are usually crooked as well. I think you can get modern radios these days that are designed to fit these trucks without the need for cutting holes..
That cab is SSSSSOOOOOO clean. You find the best trucks to work on. Glad to see you working on projects again.
I am still using PhotoBucket. Without paying they crazy pricing. Something about how long I have had a paid account continuous since 2001. Its hard to keep up with all the changes. They are threatening to pull the plug fall of this year . . Simply not going to give them 399.00 per year ransom.Randy, what is your photo hosting site?
Beautiful, maybe I missed it but what media do you use for blasting?
Wow.... I just read through most all of your thread and I must say I am very impressed. Sorry to hear about the health issues and having to get rid of Eco1 but things happen that are out of our control and you just have to roll with it. Beautiful job on all of your projects and I look forward to many more updates to come. Best wishes, Richie
That cab is sure going to be easy to work on given it is so clean, straight and has no rust.
Sometimes it is the simplest things. We tend to look for the major issue rather than starting at the basics. I do it all the time. Glad you got it going.
whats that line about seeing the tree through the forest???? fresh eyes are also amazing as i have been blessed by them a time or two. that truck looks bad *** and will be well worth the aggravation !!!!
