Replacing a detent ball in a Snap on 1942 extension
snapmom
Florida
1. parts needed. spring (from a retired dealer repair box) steel ball.
2. Tools, T7962 punch. with inset tip. (also from a retired SO dealer) and a big hammer.
3. placed spring and ball in hole, clamped the extension to anvil. drove the ball in with the punch.
4. looks and works like it was new.
Excellent. I didn’t think repairing extensions was something dealers did until seeing the tools in catalogs, and the original old repair kit.
I wonder what other brands if any, made that repair.
Cool repair tool. I have peened a couple on using a gasket punch.
Missing. Here is a practice one I did. I started with a piece of barstock, a steel ball and a spring. Drill a hole size of ball, insert spring and ball, then peened in with a hole punch
snapmom
Florida
I have gotten my parts mostly on Ebay. Also some have been given to me.
I have not seen any tools to repair 1/4 dr tools. I would try to soak it in AFT. Some have drilled small holes in the back to push the ball back up. (this seems hard) Some of the SO tools from like the 50s have a back cover that can be removed and replaced when the repair has been made.
I managed to find an SPP744 - the little spring steel tool used to hold down the detent ball when repairing a ratchet, but haven't had any luck on the punch.
The 1/4" driver isn't a Snap-on, and it doesn't have that "back door" like your example above, unfortunately.
I soaked it for about a week in Marvel Mystery Oil but still can't get the detent ball to budge. It's an oldie and most likely one that I will not be able to find a replacement for.
Provincial
Near Salem, OR
If you can find someone with an EDM machine that likes old tools, they may be able to eat away the old ball. With it gone, one could modify an old punch to swedge the hole out to get a new ball and spring in and then redo the swedge to retain them.
Paying shop rate on an EDM would be too expensive.
Snaparxon
Eastor
I have had luck tapping rapidly and repeatedly with a hammer. Hold the end on something solid like a vise or anvil. The vibration sometimes frees up the ball. Hit it hard as you can without damaging the end. I have had to use a propane torch to lightly heat as well. To much heat will destroy the spring so be careful. Don't heat it enough to change the color or the metal.
tym
Thanks for sharing, snapmom! Neat to see that special punch.
