Moving heavy items into basement shop
mhulbrock
Tuxedo, NY
Hello, Im looking for some ideas with a simple, yet annoying problem I have. My ranch home has a attached 4 car that was added on.
I have a small work shop in the basement of the home, but there is no direct access from the garage to the basement.
I would like to move a spare engine into the basement, to clear out some much needed space in the garage.
Any ideas on how to move heavy things down some basement stair? They are you typical narrow stairs, only 1 person at a time can go down them.
One strange idea i had. Mount a electric winch to my engine hoist, and remove 3 or 4 stairs at the top. Lower the motor down through the hole
-Mark
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
You might want to think again. it is a lot easier to get heavy objects down into the basement than it is to get them up again later...
Think Hoarders. ;)
But if you must:
I put in a couple of 2x4 runners on the stairs and used a small cart with 4 old lawnmower wheels tied to a block and tackle. Just make sure there are enough people downstairs to handle the load since it is tough climbing over it.
Zrexxer
Pflugerville, TX
There's always the three step method:
1. Give huge shove
2. Duck and cringe
3. Wait for crashing to stop and dust to clear
:D
Ray-CA
San Diego CA
Do you have a winch? Try mounting the engine to some block(s) of wood, then to a plywood base or to some 2x4 skids. Then, use the winch to lower the motor down stairs and again to pull it back up.
Ray
Stuart in MN
Minneapolis
An egress window is a basement window that's large enough for a person to get through. For instance, if you have a bedroom in a basement it needs to have an egress window so occupants can get out in case there's a fire.
As far as the engine goes, I think the refrigerator dolly is the simplest answer, but a a winch and skids would work as well. Before you do anything make sure the staircase is strong enough to hold the engine...is it a Chrysler Hemi or a Volkswagen?
pgreen
Venus, TX
I moved a 500lb bandsaw down the stairs of my previous house all by myself with a simple 2-wheel dolly. Be sure to strap it down to the dolly so it can't move, then go slow, one step at a time. If you put runners on the steps, you are completely committed, and no break for you. With the steps in place, you just go slowly one step at a time. If you have another person, send them down first to help support the load and ease the transition to each step.
tdkkart
Eastern Iowa
I wish I could find it, but somewhere out there is a story of a guy with a machine shop in his basement. He had already managed to get several machines down the basement stairs, but then was faced with the dilema of how to get a large milling machine into his basement shop.
He devised a method.
1st step was to find an excuse to send his wife away for a couple days.
2nd step was to cut a large hole in the floor of the dining area of the kitchen.
3rd, remove patio door.
4th, poke milling machine through patio door with a forklift.
5th, lower machine through the floor with a hoist
6th, repair kitchen floor, including installing the new laminate flooring his wife wanted so badly.
Done............
tstukel
Stuart, FL
I moved a 500lb bandsaw down the stairs of my previous house all by myself with a simple 2-wheel dolly. Be sure to strap it down to the dolly so it can't move, then go slow, one step at a time. If you put runners on the steps, you are completely committed, and no break for you. With the steps in place, you just go slowly one step at a time. If you have another person, send them down first to help support the load and ease the transition to each step...
...and to cushion the fall.
the spyder
Oregon
Done............
Now thats something I would do! :thumbup:
rsanter
visalia ca
for what you are doing, I would do the appliance dolly and friend to help.
another option I have seen is that a guy who wanted a machine shop in the basement dug an area out next to the house and put up a block wall and concrete pad. installed a door where a window was so he was able to use an Aframe type setup and hoist to lower things down to basement level
bob
6768rogues
Western NY
Build a ramp down the stairs. Put the engine on a dolly. Put the wife at the bottom to catch it. Push it over the edge.
little d
NW Oklahoma
my wood working shop is in the basement. i have a 4',by 3', by 7' gang box that weighs like a ton, lol, table saw, ect.... that goes up and down, depending on what job im working on. i do pretty much like tourque said, except i use 2 by 8's with cleats on the bottom that match the stair treads, and a hand dolly, and straps. i have a picket fence close so i hook a come-a-long to the posts, and dolly and lower/raise what i need to move like that. one of these days im going to buy one of those portable electric wenches. anyways, i do this my self, and have for years with out any help, and have never had any probs. hope this helps, little d.
little d
NW Oklahoma
lol, ya i guess it might if the posts wernt 4' in the ground in concrete. that is a pretty silly picture though, he, he, he.
tcianci
Walpole, Ma
Lay a 2x10 on the steps, skid the engine down the 2x10, no dollys nothing with wheels. You need to leave plenty of friction in the mix so the load can't get away from you. You will be amazed at what you can handle when you have control. If the load still wants to slide even on just a wood plank, attach a rope that is wrapped around a pipe that is bridging the door jambs and play it out a little at a time. I have had ocassion to assemble blocks in my basement. I would just carry them downstairs. I also was dumb enough to carry one back up with the crank and pistons in it. That was over 20 years ago, seems like they were much lighter back then.
NUTTSGT
Northern Central Ohio
Done............
I think I've heard this story before.
Seriously, a 4 car garage you you don't have enough room ?
Lay some runner on the steps, strap the engine to a 2 wheel dolly. Anchor a block and tackle to the sill plate with the other end to the dolley. Have a friend run the B&T, while you lay the dolley on it's back and take it down the steps.
