NEED HELP to ID this cast iron table
Wayfastwhitie440
Florida
I recently picked up this cast iron table and Im trying to figure out what it could have been used for? it looks like a fixture table but the holes are small and jagged. Some have been modified. Ive thought about taking a magdrill and cutting them all to 1/2 and turning it into a fixture table but at the same time just clean it and use as is becuase 1/2 seems kinda tiny. Any suggestions? Thanks P.S. the table is 30"x 61"x 3"
EdT
North Georgia
Nice looking lump of iron. From what I can see in the pictures, the holes are located in areas where there are not stiffening ribs on the back of the casting (that's a guess). Any hole drilled elsewhere would run into the ribs and would be around 3" deep to get all the way through. Possibly not a great arrangement. You could certainly make the holes bigger if you wanted. Although 1/2 " is probably big enough, a lot of the fixturing tooling is 5/8" IIR. You could also tap some of the holes to accept bolts from the top. If the holes aren't tapped or equipped with some other arrangement, you'll have to reach under the table to put a nut onto the bolts from above. If it was mine, I'd tap the holes at the corners of the patterns and see how that works out. Not a big deal to do more later. You could also consider drilling and tapping into the ribs that I speculate are on the backside. AFA what was it originally for or who made it, not a clue.
matt_i
SE Michigan
Thats cool! I'm going to WAG a bedplate for mounting some large stationary machinery (pump, large genset, engine-driven something). The holes are probably predrilled on the grid and you can easily tap the ones you want as you go.
The cast iron will be superb for shedding slag and dross.
larry_g
oregon
I'm curious if the holes are on both sides of the piece? To me it looks like a press plate with either vent holes or vacuum holes. It seems that on another post here that one called a similar piece aircraft carrier decking.
lg
no neat sig line
W
Wayfastwhitie440
Florida
No its not a solid 3". It is semi hollow underneath. I'm going to try and get a underside pic. It has through bolts on 4 spots near the edges For mounting the table to whatever .
racer-john
Newmarket, ON Canada
The clamp tooling for my mill is 1/2"-13, so if you drill out the holes use the tap drill for
1/2"-13. I have a small tooling plate 1/2" thick that I tapped to use my mill clamps.
Lelandwelds
Central Texas
My vote is for a vacuum table for plastic products
Maybe. I haven't seen every possible plastic vacuum mold set up. The auto ones don't look so " general purpose" as this one. Maybe it just looks funny without air operated actuators and stuff missing. Plastic forming is one thing I always just glanced at on the way to the welding dept.
It would make a nice out feed table for a table saw.
W
Wayfastwhitie440
Florida
Here's what the bottom looks like. The holes are 1-1/4 eye to eye spaced and where the holes are is only 5/16 thick. Hope this helps a little more . Thanks for all the help.
