MrBalll
I have a switch for a fireplace mantle that has never worked since I moved in. This switch was added recently from what I can see.
I used a non contact tester and all three showed hot.
I then used one of the two wires and small light ac/dc testers. I used the ground on a nearby light switch I knew was wired correctly. I used the good ground and all three wires of the bad switch showed a light on the probe tester. The light was a lot dimmer then when I tested an outlet, but it still lit up.
A lot of wiring in this house is terrible so it didn't surprise me. Some of the switches and plugs don't even have a ground. Just curious what would cause all three to be hot?
House was built in 64.
Edit: Haven't opened the panel and looked at wiring inside. I'd rather not to be honest. Not well versed in electrical and I also have OCD and am afraid of what I'd find inside.
(with explanations why)
