Dense wrench storage
BoostAddiction
Western North Carolina
I don't mean "stupid wrenches", though I may have called them that at one time.
No, I mean that the usual storage schemes for wrenches are all oriented in the horizontal plane, wasting all the volume above it. If you have a lot of wrenches- and I think we can all agree here that a real man can't have too many- you generally end up wasting all that space above the typical wrench rack. And a lot of racks use up a lot of area in a drawer that isn't used. So they really aren't a very dense way to store wrenches, wasting both area and volume.
Worse, those wrench racks will have empty spaces unless you have the exact number of whatever sizes the holders have. And that seriously offends my aesthetics. :)
So I thought about it, and whipped up a model in Fusion 360, a popular, powerful (and free) CAD program. This novel design offers relatively high density, depending on the number of wrenches you have in each size, and because they are 3D printed, can be made in exactly the height, color and quantity needed. For example, I could print all the SAE wrenches in red, and the metrics in gray (or black).
I put the wrench size on the top for easy ID. Eventually, I'll paint the top with a contrasting color paint, and wipe it off the top, so the remaining paint stays in the printed recesses.
This is just a quickly printed model to validate the concept and size. Production holders would be printed in a high-quality mode with much better resolution.
Here's a view of the holder in a regular 4+" drawer, showing that most of the volume is used in an area as small as I could make it. Not every holder has almost 4" of vertical wrenches, but it shows how you could stack them that way.
Here's another view:
I really like the concept, and now that the initial concept seems to work, I will design and print the other sizes, using high-quality mode, and in the colors I choose.
For the technical types, this was printed using Hatchbox Pantone 032 red PLA, on a modified Wanhao I3 Plus, using Duet 32-bit electronics at 60mm/sec, 25% infill, no raft and 200 degrees at the hot end, and 60 on the Buildtak bed.
ItsNemo
Canada
***** you can't get to the bottom wrench without taking out the stack.
I'd assume you would 3d print them all as one piece so you can reduce the space between each one if they have to be self supporting.
hoye0017
I'm thinking your going to want to leave space between stacks for your fingers. If they all sit right next to each, it would probably be difficult to reach between stacks to grab the wrenches at the bottom of a stack.
...unless you can make it easy to pull the whole stack upward?
454ragtop
Carver, MA
I suspect the real problem is you have too many deep drawers and not enough shallow. I know lifting off all the top wrenches to get at lower ones would get real old real quick.
unslow1
Illinois
If I was that hard up for space it's time to get more toolbox. No way would I ever put up with that design for something I use as much as a combination wrench. That would seem better for something rarely used.
geartow
ohio / pa border on I80
while a nice novel design, it is not good for quick accountability. and in many professional settings accountability is more important than a quality repair .
turbowoodworker
Apex NC
"For the technical types, this was printed using Hatchbox Pantone 032 red PLA, on a modified Wanhao I3 Plus, using Duet 32-bit electronics at 60mm/sec, 25% infill, no raft and 200 degrees at the hot end, and 60 on the Buildtak bed."
That is exactly how I would have done it! :willy_nil:lol_hitti
RAS61
Low Country, SC
True, but remember, they're all the same size. I imagine the 2 favorites would go on top, and the rest would never be used. I've never had the need for more than 2 wrenches the same size, and don't know how I'd use them with only two hands, so this is more of a long term storage solution to tools that have been collected but rarely get used. Give me a shallow drawer where they're easy to get at, but then I don't own nine 13mm combo wrenches that need to be stored.
XJSuperman
Central Iowa
Pretty slick design there. As others have said, options are to get more toolbox, or avoid altogether, but why not print the same thing only more like a steel rack. I don't really have anything to draw with here at work, but Im thinking small inclined arms to act as shelves for each wrench. Then you could remove each individually. You'd still need a little space between each stack but it could be done.
Something like this only more condensed and stood up on a little base like you have in your design. It could be kept to a similar height.
apollo11
State Of Reality
I agree
and to the "they are all the same size" thought, while I have multiples of say, 13 mm wrenches, I have different styles of them and would not want to stack them even if I could.
My .02 :beer:
wkndwarrior29
NorthEast
I think it's a pretty nice idea. I keep my main sets spread out but all of the other wrenches stacked to make room - this would work well to keep them out of the way but available. Example would be the Jumbo's and flare wrenches.
Sent from my XT1650 using Tapatalk
BoostAddiction
It's actually easy to pull out the whole stack if I want to get a specific wrench, but most of the time, whatever ones are on top are fine. I just don't need to get to a specific one very often. In practice, I might keep the ratcheting ones on top, but since its as easy to lift the whole stack as it is to pick off the top couple, it's really not a problem for me.
As for accountability, I'm not repairing aircraft- it's just a home garage, so I don't have to prove I didn't leave a wrench in an engine cowling. :)
I actually have lots of storage space in the garage, as you can see by checking out the link below. I've even added a bunch more since then, so this isn't a result of insufficient storage. It's really about making the most of the storage I have.
fowldarr
Coastal Oregon
Two additional ideas:
1) What about printing one large tray with all the sizes (same design and idea, just one piece).
2) Design it to hang from pegboard.
I don't know if I would use this, as my particular brand of OCD sorts by size and brand, and I don't have that many of any one size of the same brand.
I like the idea though.
unslow1
Illinois
I have seen something similar in NASCAR and NHRA toolboxes. What they had were stacks of identical wrenches. That seemed like a good idea for them. They probably use a limited number of sizes and multiples of each.
MrDeerHunter
I really like the idea and it is a better solution to me than what I have done on a pegboard. I keep all my same wrench sizes on the same peg hook. I typically use my gear wrench ratcheting wrenches so they stay on the outside but I never know when I need an extra or a flexhead. Would work really well for weekend wrenchers like myself that have a lot and don't want browse through thirty drawers to find that one wrench set.
Sent from my Moto Z (2) using The Garage Journal mobile app
fred.foobar
I personally wouldn't want to keep having to pull the top ones off to get to one in the middle, but this really isn't about me. ��
That could easily be resolved by flipping the wrenches over, docking the open end onto the rod. Then all you'd have to do is lift the group an inch or so, pull back the target wrench til it clears the post, then rotate 90 degrees and slide out. Wouldn't even need to modify the design.
Great way thinking outside the box to get better use of your box! ��
Gmonkee
Why would one need eight 13mm wrenches at the ready?
The top three would be the only ones used and all the rest little more than ballast in the bottom of the drawer.
For a storage box for a tool reseller that is killer, for a working tech overkill.
kctyphoon
Jersey/Staten Island
Not good for storing 10 of the same sized wrenches, but -
Two magnetic rails on the top and bottom edge of drawer. All wrenches magnetically charged, and sticking to each other. Will stay in place even with some removed. No wasted space.
JR 42
Sunny Seattle
Does using magnetized wrenches bother you? I think that would drive me nuts...
JR
4 FN 27
Minnesnowta
Badass...love the OCD side effect...but I have to side with
I love it however...3D Printing is the newest frontier in my pursuit of craziness in the Garage. Just I don't do plastic well...I am a Metal Head. I am investigating Desk Top Metal. Going to a show next week.
I have place these photos here before. My quest, like yours, I was never happy with what was available for Wrench Storage...thus I invested a few hours and design these Wrench Racks and made them. I happen to own a Fab Shop so it does come easy...
Tallpilot
Orlando
I will never get tired of seeing these pictures because sometimes I think I might have too many wrench sets but you always remind me that I really should buy a few more and stop being miserly.
I would like to see your socket roll cab at some point as well.
:beer:
4 FN 27
Minnesnowta
:beer:
Feed the addiction!!!
Here are couple of shots...
Packard V8
Spokane, WA
I'd buy those. Since you have a fab shop, you're used to pricing your work. How much to duplicate a set?
jack vines
4 FN 27
Minnesnowta
jack vines
Jack these are designed around Craftsman Sets from the 90's. Unless you have the exact same set(s) they will not function correctly...more than likely. Just say'in...
The date on this check looks old. Can you still cash it?
It is. It was the first check we received from NHRA's Souvenir Trailer that was selling our Tee Shirts. Rather than cash the check I decided to keep it. I was mind boggling to think somebody actually wanted a Tee Short with my Car and Name on it. The rest of Checks after that we deposited and put towards the finish line goals...LOL...
AffableCurmudgeon
Triad Area NC
Very cool! :thumbup:
