So I have an extra 500, and was wondering what everyone would suggest adding to my tools.
I will attempt to list off what I have now:
Snap-on ratcheting hard handle screwdriver(green)
2 buddy blasters from trusty cook, the smaller 2
set of wera screwdrivers
set of felo screw drivers
kobalt set
impact sockets 3/8 and 1/2
pass through socket set
matco plier set SP11SET
gear wrench ratcheting wrench set
stream light stinger
I think that covers most of it.
My plans for tools are to work on cars, around the house, and motocycles.
Pick from this list:
Lincoln spindle for large spool
Needle scaler HF
Fish tape HF
Fish sticks HF large
5 Piece Front End Service Tool Set HF 62789 74.99
Fluid film
Anti-splatter nozzle dip
Welding coat
Pressure washer
Fluid extractor pump
4 Piece Short Air Chisel Set HF 68277 5.99
Distilled water - more
Vinegar - gallons
Thread restoration kit Craftsman SAE and Metric 48 pc 971 2750 54.99
External retaining ring pliers Matco
Crocus cloth
Factory service manual 2002 Astro Vol II
Sheet metal cutter - air
Electrolysis Tank
For Service Cart:
Better organization for wrenches
Mount for paper towels
Mount for pry bars?
Shelf
Side cabinet? - no
Electrical outlet and cord hook
Air hose hook and fitting
Working on better storage for service cart. Took numerous things out of packaging to save space.
Would like:
SAE everything...
Shallow sockets?
Pullers
Dental picks
Socket trays
Electrical Terminal Kit and Crimper
Wrenches long box end metric?
Ironton Retractable Cord Reel - 40-Ft., 12/3, Triple Tap 49666 69.99
45 Pc Titanium Nitride Coated Alloy Steel SAE Tap & Die Set HF 61411 84.99
45 Pc Titanium Nitride Coated Alloy Steel Metric Tap & Die Set HF 61410 84.99
21 Pc Carbon Steel SAE Tap and Die Set HF 51398 9.99?
40 Pc Carbon Steel Metric Tap and Die Set HF 39384 14.99?
60 Pc SAE & Metric Tap and Die Set HF 60366 37.99
Offset Box Wrench Set Metric 8 pc HF 32042 15.99
Offset Box Wrench Set SAE 8 pc HF 32041 15.99
Hex sockets ball end long 3/8" SAE HF 67885 14.99
Hex sockets ball end long 3/8" Metric HF 67888 14.99
Neiko 40447A Rechargeable Underhood Work Light | 202 SMD LED Bulbs | 1,200 Lumens Max Brightness | 8,000 mAh Li-ion Battery | 2 Brightness Modes 79.95 Amazon?
Long pry bar 48" or longer C'man? $39.99 or Mayhew?
Spring compressors - Would like center one
Special pliers cable cutters - Have some
Not needed yet:
Large Bearing Separator HF 3979 29.99
1/2 in. Drive 18 in. Breaker Bar HF 67932 9.99
3/4 in. Drive 20 in. Quick Release Breaker Bar HF 98270 21.99
Master Fuel Injection Pressure Test Kit HF 62788 89.99
1/2 in. Drive Front Wheel Drive Axle Lock-Nut Socket Set 7 Pc HF 62842 39.99
1/2 in. Drive Super High Torque Lug Nut Impact Socket Set 11 Pc HF 69829 69.99
2 Pc. Professional Automotive HVLP Air Spray Gun Kit HF 61472 49.99
Power Probe IV
LED 12 volt for testing coil on plug, etc. ($3 or so at electronic supply house)
Mapp gas - CL
11 or 18 piece brake caliper set HF?
Disc Brake Pad and Caliper Service Tool Kit 18 Pc ABN Sears 24.99
Oil Filter Wrench (assortment of strap and cap types) - Have some
IRWIN Tools BOLT-GRIP Deep Well Bolt Extractor Set, 5-Piece (3094001) 34.23 - Have HF
Irwin damaged fastener tool set Screw extractor set?
3 in. High Speed Composite Air Cut-Off Tool HF 68832 19.99 Have reg HF one
Bolt-Type Wheel Puller Set HF 62620 14.99
Interior body panel tools - Have HF plastic - couple more HF
Body panel clip pliers HF 67399 7.99
Push pin pliers HF 67400 9.99
Noid Light and IAC Tester Set 11 Pc HF 97959 39.99
Hose disconnect tools HF
3/8 in. Offset Oxygen Sensor Wrench HF 97177 6.99
7/8 in. Oxygen Sensor Socket HF 69022 7.99
Stubby wrenches
Rear caliper cube
Cordless impact
Quick disconnect tools
Axle nut socket set powerbuilt O'Reillys?
Leslie blind seal puller
CV joint boot band installation tool
Air chucks for pressure testing cylinders
Compression tester
Fuel pressure gauge
Vacuum gauge
Chain Wrench?
Stud remover
AC tools
Disconnect tools
Big channellocks - have cheap ones
Curved needlenose
Eastwood pro flaring tool set - use small set
Specialty wrenches
Cable actuated hose clamp pliers
MAC flare set
Balance puller
Block tester
2nd cart
HAVE:
02543?
82307?
03655?
RATCHETS, SOCKETS,EXTENSIONS AND SETS:
Gearwrench 8922 23 Pcs. SAE Pass-thru Socket & Bit Set 8922 33.00
Kobalt 7-Piece SAE 3/8-in Drive 12-Point Flex Socket Set 0236279
Kobalt 7-Piece Metric 3/8-in Drive 12-Point Flex Socket Set 86218
Kobalt 22-Piece Thru-Ratchet Set 70128
Kobalt 7-Piece 3/8-in Drive Hex Driver Socket Set 0338623
Kobalt 24-Piece Standard (SAE) and Metric Mechanic's Tool Set with Hard Case 0338552 Kobalt 35-Piece Standard (SAE) and Metric Mechanic's Tool Set with Hard Case 0338358
Kobalt 16-Piece Standard/Metric Mechanics Tool Set 0338511 35.00
Kobalt 7-Piece 3/8-in Drive Hex Driver Socket Set 0338622 19.00
Kobalt 11-Piece Standard (SAE) 3/8-in Drive 6-Point Socket Set0338614 26.97
Kobalt 11-Piece Metric 1/2-in Drive 12-Point Socket Set 0338616 27.97
Kobalt 11-Piece Metric 1/2-in Drive 12-Point Socket Set 0338621 37.97
Kobalt 11-Piece Standard (SAE) 1/2-in Drive 12-Point Socket Set 0338620 37.97
Kobalt 11-Piece Metric 3/8-in Drive 6-Point Socket Set 0338615 26.97
Kobalt 11-Piece Metric 3/8-in Drive 12-Point Socket Set 0338617 27.97
Kobalt 10-Piece Metric 1/4-in Drive 6-Point Socket Set 0338637 14.97
Kobalt 10-Piece Standard (SAE) 1/4-in Drive 6-Point Socket Set 0338636 14.99
Kobalt 24-Piece Standard (SAE) and Metric Mechanic's Tool Set with Hard Case 0338552 19.98
Kobalt 20-Piece Standard (SAE) and Metric Combination Mechanic's Tool Set 0338509
1/4 in. Drive Professional Low Profile Ratchet HF 62329 16.99
3/8 in. Drive Professional Low Profile Ratchet HF 62328 17.99
1/2 in. Drive Professional Low-Profile Ratchet HF 62330 19.99
1/4 in. Drive Professional Flex Head Ratchet HF 62331 16.99
3/8 in. Drive Professional Flex Head Long Handle Ratchet HF 62333 24.99
1/2 in. Drive Professional Flex Head Long Handle Ratchet HF 62332 29.99
1/4 in. Drive Heavy Duty Composite Ratchet HF 66312 8.99
3/8 in. Drive Composite Quick-Release Ratchet HF 62290 9.99
3/8 in. Drive Indexable Head Ratchet HF 62316 16.99
1/2 in. Drive Indexable Head Ratchet HF 62315 19.99
1/4" insert bit ratchet
Spark plug sockets - variety
4 Pc 3/8 in. Drive Quick-Release Extension Bar Set HF 67976 19.99
4 Pc 1/2 in. Drive Quick-Release Extension Bar Set HF 61968 22.99
9-piece-wobble-extension-set HF 31203
4 Piece High Visibility Socket Adapter Set HF 67925 4.99
3 Pc Universal Impact Joint Socket Adapter Set HF 67986 9.99
9 Pc Wobble Socket Extension Set HF 61278 14.99
9 Pc Wobble Socket Extension Set HF 67900 14.99
21 Pc 3/8 in. Drive SAE & Metric High Visibility Socket Set HF 67905 22.99
21 Pc SAE & Metric Go-Thru Socket Set HF 62305 19.99
1/2 in. Drive Extendable Ratchet HF 62311 17.99
Gear Wrench 23-piece 1/4" Drive Metric Socket Set 8923 25.00
1/2 in. Drive Impact Flip Socket Set 3 Pc HF 62491 11.99
13 Pc 1/2 in. Drive Metric Impact Socket Set HF 69345 25.99
8 Pc 1/2 in. Drive Metric Impact Hex Socket Set HF 61337 29.99
8 Pc 1/2 in. Drive SAE Impact Hex Socket Set HF 67893 29.99
3 Pc 3/8 in. Drive Impact Wobble Socket Extension Set HF 67065 8.99
3 Pc 1/2 in. Drive Impact Wobble Socket Extension Set HF 67066 9.99
7 Pc 1/2 in. Drive Metric Impact Swivel Socket Set HF 67911 29.99
7 Pc 3/8 in. Drive Metric Impact Swivel Socket Set HF 67908 24.99
E reverse Torx sockets metric
37 Pc 3/8 in., 1/2 in. Drive SAE & Metric Impact Socket Set HF 68011 29.99
13 Pc 1/2 in. Drive Metric Impact Deep Wall Socket Set HF 69279 24.99
13 Pc 1/2 in. Drive SAE Impact Deep Wall Socket Set HF 69280 24.99
8 Pc 1/2 in. Drive Impact Star Bit Socket Set HF 61336 29.99
9 Pc 3/8 in. Drive Metric Bolt Extractor Socket Set HF 67894 24.99
Flex sockets
Blow mold 1/4" socket and ratchet set Gearwrench
Universal joint set metric for sockets
Universal joint set SAE for sockets
4 Pc 1/2 in. Drive Impact Socket Extension Set HF 67972 9.99
4 Pc 3/8 in. Drive Impact Socket Extension Set HF 67926 7.99
Impact extension size converters HF
3/8" Extensions locking and regular HF
WRENCHES:
Torque wrench HF 3 sizes
Crowsfoot wrenches metric
GearWrench 87329 SAE X-Beam 29-Piece Ratcheting Wrench Set
11 Pc Fully Polished Metric Long Handle Combination Wrench Set HF 47067 24.99
14 Pc Metric V-Groove Combination Wrench Set HF 63063 39.99
14 Pc SAE V-Groove Combination Wrench Set HF 61726 39.99
GearWrench 9700 7 Piece Flex-Head Combination Ratcheting Wrench Set SAE 9700 48.41
GearWrench 9900 7 Piece Flex-Head Combination Ratcheting Wrench Set Metric 9900
GearWrench 87329 SAE X-Beam 29-Piece Ratcheting Wrench Set 87329
1/2 in. Professional Air Impact Wrench HF Earthquake 68424 89.99
Air ratchet - Husky
SPECIALTY TOOLS:
Heavy Duty Slide Hammer and Puller Set 16 Pc HF 63268 69.99
4 Piece Solid Brass Industrial Quick Coupler Set HF 68241 2.79
1/4" Female to Male Swivel Connector HF 68196 4.99
16 in. Ball Joint Separator HF 63420 7.99
Bearing Separator and Puller Set HF 62593 49.99
Front Wheel Bearing Adapters HF 63260 119.99
Ball Joint Service Kit for 2WD and 4WD Vehicles HF 63279 89.99
14 Piece Master Ball Joint Adapter Set HF 62785 72.99
Brake Bleeder and Vacuum Pump Kit HF 60770 24.99
Tie rod and Pitman arm puller HF 62708 14.99 - Get puller kit?
MISC.:
1/2" Hitch lock HF
MIG pliers HF
Flexible hose for grease gun HF
10 Piece Bearing Race and Seal Driver Set HF 63261 49.99
Seal Driver Kit 18 Pc HF 35555 19.99
20 oz. HVLP Gravity Feed Air Spray Gun with Regulator HF 69705 29.99
Medium Barrel Air Impact Hammer HF 69866 13.99
3 Piece Long Air Chisel Set HF 68276 7.99
Air Hammer Replacement Chisel Spring HF 68275 1.69
Air Hammer Quick Release Chisel Holder HF 66621 4.99
2 Pc 10 in. Internal And External Circlip Pliers HF 60593 9.99
Astro Pneumatic 9401 10-Piece Snap Ring Pliers Set APT-9401 28.99
Drum Brake Spring Pliers Kit 3 Pc HF 97804 12.99
Stainless Steel Tweezers Set 6 Pc HF 93598 5.99
1/4 in. Drive 5 in. Breaker Bar Herbrand (2) 5.00
3/8 in. Drive 17 in. Breaker Bar HF 67931 8.99
1/2 in. Drive 25 in. Breaker Bar HF 67933 12.99
1/2 in. Drive 18 in. Ratcheting Breaker Bar HF 67957 21.99
1/2 in. Drive 25 in. Professional Breaker Bar HF 62729 19.99
Pry bars Craftsman 3 pc
4 Pc Heavy Duty Pry Bar Set HF 01654 10.99
Left Hand Drill Bit Set 13 Pc HF 61686 7.99
Titanium Nitride Coated Drill Bit Set 29 Pc HF 61637 14.99
Titanium Nitride Coated High Speed Steel Step Bit Set 2 Pc HF 96275 19.99
Titanium Nitride Coated High Speed Steel Step Bit Set 3 Pc HF 60379 13.99
2 Pc 20° Offset & 45° Angle Long Reach Pliers HF 61587 7.99
Long Reach Hose Grip Pliers 3 Pc HF 37909 14.99
2 Pc. 16 in. Long Reach Pliers Set HF 38598 11.99
Pliers misc
22 Pc Screwdriver Set HF 69420 11.99
Screwdrivers misc, and HF
Small screwdrivers misc
4# hand sledge
4 lb. Neon Orange Dead Blow Hammer HF 41800 11.99
Rubber mallet
Brass hammer
Alignment punches
Chisels - Have a selection
Safety glasses and face shield
Mini Pick and Hook Set 4 Pc HF 66836 free
Magnetic parts dishes 4" and 6" HF
Coolant tester
Rivets
3-in-1 Riveter Kit HF 94300 16.99
Mirror & magnet tools extendable
Flashlights misc
Brush - Have
Teflon tape
Tubing cutters 2
Hacksaw - Have a couple
Grease gun - Learn to use
Flaring tool set small - Good for now for brake lines
Vise grips - Have a few
Channel locks
Ryobi Dremel (type) with 3 accessory kits
Files
Gasket scraper
Office paper clips for cam belts
ELECTRICAL:
Lisle 56500 Terminal Tool 9.99
Helping hands HF 60501 4.99
10 in. Cable Cutters HF 61422 6.99
Multi-meter Milwaukee
Clamp meter Milwaukee
7 Function Digital Multimeter with Backlight HF 92020 free
6/12V Circuit Tester with 5 ft. Lead HF 30779 3.99
Electrical tape
Battery terminal cleaner
Wire Stripper
Feeler Gauges/thickness shims
Spark Plug Gap gauge
Timing light
Battery charger
Side cutters
MEASUREMENT:
Dial caliper
Electronic caliper HF
MicrometerS
Calipers HF
Supplies:
Super lube HF
Brake cleaner
Kroil
PB blaster
Wheel bearing grease
Brake lube
Anti-seize
Shop towels
Paper towels
7 mil Nitrile Powder-Free Gloves 50 Pc X-Large HF 61774 9.99
9 mil Nitrile Powder-Free Gloves 50 Pc X-Large HF 61743 12.99
Red Mechanic's Shop Towels 14x13 50 Pk. HF 63365 12.99
SHOP EQUIPMENT:
Vise - Have a few
Ox/ac set incl. cart
Pancake air compressor - Porter Cable
Speedaire 3Z494 5HP 60GAL 1PH 240V 16.6 CFM at 175PSI
Sears 106.?????? 2HP 20GAL 20A 240V Horiz. Compressor
Air pressure gauges and fittings
Bench grinder 1/2HP Baldor
Grinders with wire wheels and stones and buffs
Drill press Buffalo
Bridgeport
Lathe South Bend
Horiz. band saw Kalamazoo
Parts washer
Arbor press Grenard
12 ton H-Frame Industrial Heavy Duty Floor Shop Press HF 33497 119.99
Hose reel
Disc sander Kalamazoo
Belt sander Kalamazoo
Anvil
AC DC stick welder ARC-180 HF 44568
AC DC "Tombstone" stick welder Lincoln
Lincoln Weld-Pak 3200HD 120V MIG
Plasma cutter
OTHER:
10 in. Flush Cut Pull Saw HF 94722 7.99
10 In. Japanese Style Double-Edge Saw HF 67058 9.99
Cornwell OBDII Scanner OWC9575. Same as OTC2109 and Actron CP9575 40.00
UtiliTech 1000 lumen work light
Milwaukee 12V and 18V cordless drills and impact drivers
4-1/2 in. 4.3 Amp Angle Grinder HF 60625 (2) 13.99
4-1/2 in. 4.3 Amp Angle Grinder HF 68645 13.99
1/4 in. Air Angle Die Grinder HF 32046 12.99
3 in. High-Speed Air Cut-Off Tool HF 60374 7.99
18 Pc SAE & Metric T-Handle Ball End Hex Key Set HF 63167 17.99
1.5 Ton Compact Aluminum Racing Floor Jack with Rapid Pump® HF 62160 79.99
Arcan Aluminum floor jack 3 ton ALJ3T 249.99
3 Ton Steel Jack Stands HF 61196 21.99
6 ton Steel Jack Stands HF 61197 39.99
Pneumatic Roller Seat HF 46319 25.99
40 in. 300 lb. Capacity Low-Profile Creeper HF 69262 23.99
First aid kit
Fire extinguisher
Engine stand
1500 lb. Capacity Vehicle Dollies 2 Pc HF 67338 52.99
Oil drain containers
Funnels
Wheel chock
Trash can
Broom
Dustpan alum.
Shop vac.
Hose reel ceiling mount 3/8"
Engine stand
Engine hoist
Fish sticks HF small
Argon tank 80, 125 or 150 or 330! and 25/75
Vulcan ArcSafe™ Auto Darkening Welding Helmet HF 63749 139.99
1/4" Male Steel Industrial Swivel Plug HF 68185 1.99
Air hammer Astro Pneumatic 4901 Kit 210.71
HF Braun foldable light
HF Braun Underhood light $30 w/coupon
HF Long screwdrivers
HF 20 Ton Air over hydraulic bottle jack
HF Leather apron
Silver And Deming Drill Bit Set 8 Pc HF 61892 34.99
HF Electrical screwdrivers both sets
Bill
