OK one empty File cab moved, one to go! The second is 2" wider and an inch taller... may be a LITTLE tighter getting it placed...
/Made some more wrought iron fence....
Very Nice! If you don't mind - where do you purchase the punched channels?
Steve
Thanks!VERY impressive! And nice shop! Is that vise on the metal bench an old US made rotater?
Changed the accessory belt on the Cayman as part of its 40,000 mile service.
The belt is accessed from the passenger compartment, through a panel immediately behind the seats. There's also an access panel in the trunk area for getting at the intake filter and the top of the engine.Do you get to that from the passenger compartment or the trunk? Curious. Been looking at Caymans and Boxsters.
"Finally got a heater installed and a little insulation put up!"
7D2Nova Congrats on the heater install.
Interesting looking heater is that a forced hot air with an outside vent ?
Just remember the insulation backing is flammable.
Turned-up the heat, had a weekend beverage and welded. Made a few rebar snowflakes for a buddy who likes to downhill ski. Then bent some 1/8" plain steel rod and tack welded some "Stick 'em Up" hot dog/sausage cookers. I took the inspiration from barbiethewelder.com and few other ideas on the internet. I think they'll be the hit of the Super Bowl tailgate tomorrow.
Detached garage - pan drop, filter and fluid change on the 6R60 in my 2007 Explorer. It seems to have resolved my complaints on the test drive.
Attached garage - new springs and cables on the garage door. I went to do a small adjustment the other day on one spring and noticed the door cable was down to just a few strands. Since it's over 20 years old I replaced the springs also. This door has extension springs.
, With its drawers int near imovable... Then installed most of the drawers and consolidated my C clamps (again...) Then got side tracked as my youngest daughter popped in unexpectedly.Worked on my 1948 Sears & Roebuck trailer on Saturday. Got the cargo rack I built bolted down nice and then started work on mocking up the underbody toolboxes Ive been hanging onto.
That is a cool trailer. Where did you get something like that? Thought they'd all be rusted away by know.
