cjcocn
Manitoba, Canada
lol ... i've been checking out the earlycj5 forum since it was posted here this morning and i'm pretty sure that i am going to be building myself a trailer similar to those recently posted
it will be for my 99 xj
polexican23
burbs-Illinois
mind sharing the specs on the heater and why electric over gas?
Finally got a heater installed and a little insulation put up!
7D2Nova
It's just a used electric furnace I got from a guy that is in the HVAC industry. It works great! He said the people were just upgrading their HVAC system. I don't have to many specs on it. I know it has the 15kw heating element in it. The only reason I went electric over gas is because my house is all electric. Didn't want to deal with running a gas line just for the garage.
fordkid88
Put the legs on the welding table. Ran out of argon so I can't cap the bottom of the legs and put casters on until I have extra cash, well I could stick weld them on. I have to do the plumbing and wiring. I also have to drill, tap and countersink 21 more holes for the slats. Next project is to turn that red side cabinet into a really cool welding cart.
My little shop is slowly turning into something awesome, its also turning into a really mess with 12 different projects at once. Today's real project will be cleaning the sob after I get back from local tech school to start enrolling in the welding program.
Happy in NC
Connelly Springs North Carolina
I put wheels under my Steelcase File cabinet and loaded it with tools. Still needs paint but rolls well and holds plenty of cutting,wire brushing and buffing supplies.
Mounted my wet millstone and plumbed it to a cheap temporary table.
Cleaned up and lubed my grinders.
And re purposed a medical equipment table to see how it would be as a welding table.
https://www.garagejournal.com/forum/album.php?albumid=6214&pictureid=80501
https://www.garagejournal.com/forum/album.php?albumid=6214&pictureid=80502
fordkid88
Did more. Tire rotation on the wife's care and made a prototype rocket stove to see how well they worked. I'd like to make a rocket stove heater using probably an old air tank or propane tank. Ran it for 45 minutes inside the garage and it did not fill with even a little smoke.
isb cornbinder
I serviced my EVOLUTION walker. I shortened the hand brake cables by 9 inches and re-routed them so the cables would not get caught up on "so many things".
The brake cables follow the tube down to the brakes without the loop, now.
I found this POS on Craigslist and bought it for $35.
I have this same model for in the house only, and it cost ten times as much.
I am pleased to have these walker. They make the difference between sitting around like a lump and getting out there and walking. I went Air Liquide today and bought their stock of Walter 3 inch zipcut discs. I also ordered more of them. I got a price reduction of nearly a dollar a disc.
https://www.walter.com/products/abrasives/cutting
chrismenke
Sam's Clam Disco, CA
I cut a slab of granite for the outdoor kitchen. Then I broke down my wooden Big Green Egg table and sent it away via craiglist free.
NewShockerGuy
Northern Virginia / DC
So the Grimmspeed units open the hood to almost 90 degrees & you don't need to change the mounting points? Hmmm, I may have to get some of those.
Yes sir. Same exact mounting spots as my Tein. The grimmspeed give all hardware provided. I read that the upper hood mounts were plastic. That might have been the case early on when they came out with these a couple years ago but mine are definitely metal. I looked up their instructions on their website and they have an older strut design as well so I am guessing no one on their site updated anything. Non the less install really should only take you and a helper (to hold the hood) 10-15 minutes...if that.
In terms of looks I think the Tein are far superior. They just look so nice. It's shame Grimmspeeds don't look nicer. They don't look bad mind you at all, but just more simpler/basic compared to the JDM hotness of Teins...lol
-Nigel
DOT headlight are designed to keep from blinding oncoming drivers. I'm seeing a lot of cars with high intensity lights, and either they have their brights on all the time, or the lows are not designed right and blind oncoming drivers. I get it from the back too. When my visors are brightly lit up from the car behind...
smalltown
Western Maine
I'm with you outlawmws. Sometimes those light are so bright I have difficulty seeing.
I wonder if they even realize that they blinding the oncoming driver.
EOC_Jason
Bentonville, AR
God that annoys the **** out of me, especially when it is some tiny car like a Honda Civic and I drive a 3/4-ton 4x4 truck and I'm pretty high off the ground. If I'm blinded like a bat I can only imagine how bad other people are. Most of the time it's idiots driving with their brights on, which to me doesn't make sense when you are driving in-town... Sure out of town on back roads I understand but when the freaking streetlights give enough illumination where you could even drive without your headlights on, driving with your brights is just an a-hole thing... I will flash my brights at them but I would say only like 1-in-10 maybe realize it and flip to their regular lights.
thejunkmanadv
Makin' another video.
https://scontent-dft4-2.**.fbcdn.net/v/t1.0-9/27655325_1810135585697531_5535497854771998676_n.jpg?oh=f2a321236eaf49009a9e151c2a5cabd2&oe=5ADE0D49
LS6 Tommy
Northern NJ
I did a mechanical resto on that exact crane. I think it was a Nylint Michigan? It was one of the toys at my Grandpa's house when I was growing up. I fixed the working parts so my cousin's son could play with it. He also has all my Tonkas. I hope to get them all back someday relatively soon...
Tommy
Jfrowell
Hello from Winchester VA. Moved here from CA 3 years ago. Love the country and a decent size shop. Jerry
HappyCamperIV
Michigan, USA
I decided I needed a shop cart, so:
I have been eyeballing one of those nice grey injection molded, roll around shop carts for some time now. I decided it was time to just shut up and buy one. After a bit of research, I discovered those little suckers are expensive! I was finding nice ones for $125 - $150 (us.) That just seemed ridiculous. I couldn't do it.
I went over to the scrap wool pile and discovered I was one big wooden dowel and two casters short of having a whole cart. Off to the local board store and I had everything I needed for <$20.
As it turned out, it was a pretty fun little project. I ran the 4X4's through the jointer and glued the parts up. Lots of work with my block plane and some sanding and a couple of coats of Danish oil and this is what I came up with.
It rolls nice and is solid as a rock. I think that's all I could ask for.
dittle fart around
Vancouver, Washington, USA
Plus you get the satisfaction of building something useful in your own garage. Now that's what its all about.:beer:
madison069
Monroeville, PA
Turned a piece of wood into a valentine day present for my wife.
ptgarcia
Alta Loma, CA
Nice; and beefy, too!
apollo11
State Of Reality
I installed LEDs not HIDs
They are in DOT housings.
C_F
Utah...SNOW BLOWS!
Welcome to the forum! That's quite a diverse group of toys in your garage. :thumbup:
-Nigel
Thanks for the reply, I am definitely going to look into these. :beer:
Vegaman_Dan
Pacific, WA
Went out to the garage feeling that I should do *something* productive after work instead of staring at a computer monitor cruising Youtube videos on welding, car repair, fabrication, etc. Didn't know what I would do, but decided to find something to make the place better.
Cleaned off two wire rack shelves that had become cluttered. Put my shop digital camera on the battery charger- it had been three years and 500 photos, but the battery finally was too weak to run the camera, so that got a 3 hour charge.
Gloves. How many gloves do you have? I keep buying them and stashing pairs in every vehicle, shed, garage, etc. Found I had too many mismatched pairs, some with damage, etc. Tossed any bad gloves and resorted them, got a small plastic bin to put on the wire shelf for 'active' gloves I would actually use.
BOLTS. I have good storage for new bolts in their assorted areas and trays. But what do you do with all the misc small number of bolts you collect over time? That one odd bolt for the lawn mower, or some tool specific bolts. Maybe a bolt pack of some sort you didn't use. You can't just throw out bolts! I've had bolt/screw coffee cans in the past, but decided this time instead of filling up trays or such with one off bolts, I'd just dedicate on single 5 gallon bucket for this purpose. Yes, I will have to dig for stuff if I need it, but at least it's all in one place for those odd ball used bolts that I have no idea what it was for. Eventually I can just recycle it. Don't really have a better solution, but at least it won't be horizontal space clutter.
Bad Eye Bill
New Brunswick Canada
That sir, is a fine piece of work. Well done.
It's to damn nice to be in a garage, it'd look good haulin' stuff around on a patio, deck, or around a pool.
madison069
Monroeville, PA
I dig that wood cart! I can see using it in my wood shop area but on my auto side it will just get dirty really fast.
