I installed LEDs not HIDs
They are in DOT housings.
OK that is good, However there are two parts to being DOT compliant and not binding folks: The housing AND the bulb, of whatever lighting tech. If the bulb doesn't do the right thing and position right, as well as cut off the beam in the right places, its going to blind people.
Simple tests: reasonably dark, stand in front of the car on level ground with the lows on: note where the light cuts off on you. Walk out 20-30 ft and see where it is: it should be LOWER cutoff on your legs.
Or you can just park with the lights on a wall that distance away, Stand at the head light, mark where the center of the headlight is on your leg and see if the cut off is the same or less on the wall.
Just a couple of quick and dirty checks.
Seems like every time I see white lights, they are either on bright, or they are not DOT Spec. :dunno:
I wish the cops would start writing $3-500 tickets for illegal lights... 'Cause when they get someone killed, the perp just keeps driving on..
Fuelboat
Changed oil, replaced spark plugs, replaced air filters, drain and refilled gas in mower, trimmer, blower, pressure washer, generator. Sharpened yard tools.
Fix Until Broke
SE Wisconsin
Good LED's have a nice cutoff, so if properly adjusted shouldn't be any brighter coming head on than HID's.
I installed them on my DD and the white light makes it much nicer to drive at night.
I'm so sick and tired of this reasoning - this is ONLY true in a perfectly flat and smooth world with no hills, curves, bumps, elevation changes, anything. When we all start driving in such a world, let me know.
bmxdad - this isn't directed specifically at you, the OEM's have the same rationale on some of their vehicles. New Cadillac SUV's with LED headlights are really bad.
bmxdad
Puyallup, WA
I get what your saying. It's the glare that is bad ... usually headlight lens designed for LED's have less glare then the HIDs, those are the ones I don't like .. to much glare.
56vette461
Jfrowell:
Okay let me see if I can get my head around this one!
1. He moves from Calif.
2. He gets a shop
3. Inside said shop he has a Stearman, a VW, a corvette, what looks like a bathtub Porsche on a lift, and a boat
4. He shows up on GJ with one pic and little details on the toys.
I AM Jealous. Bring on the details with pics please.
slamin81
Scott County,Indiana
almost done with the walls in the garage two sections left to do. pretty pumped to start the décor lol:thumbup:
also found that cool old anti-freeze can.
jwh
Rochester NY
I remember seeing a can like that....probably around 1967. Dad's '64 Ford Galaxy was low on antifreeze, gas station owner pulled one off his shelf for the fill up.
John.
driftpin
My routine is different now that we both retired. Some days, I feel industrious, rise early, and do things all-day. Other days, I take it easy, and see what I can do for my spouse. No end of things to do, and I may start keeping a log of what I want to accomplish. Prior to this, it's just been a mental list, but I may try a spreadsheet to see if formal organization of projects will result in a more-orderly approach, and completion rate.
Speaking of which, (organization of projects) a friend of mine, whose two brothers developed a software system for construction management, and who have been running the company, experiencing steady growth, just sold the company for a half-billion dollars! I don't know the brothers, but my friend is a hard-working family man, an entrepreneur in his own area, and he's done a lot for the community and for his field of work in his professional role.
So, I don't have a new router adaptation like Kay Mc. did for her table saw (a good-sized shop, and good work on the router adapter table extension) and that 4x4 wood roll-about table that GJ member Happy Camper IV made, a good design, makes me want to go use my table saw and RAS to scale something like that for an engine-build table for motorcycle work. Awhile ago I got a Handy-Lift for motorcycle work, just a fabulous addition, and it will save my poor aching back, though I haven't yet made a lot of use of it.
I did add some lighting to my small 2-car garage/shop. I added brackets off the angle irons for the high-lift garage door track (as 'high-lift' as it can be in a small residential garage, no room here for a 30' x 50' pole barn!) so I could suspend four four-foot FEIT LED shop lamps below the open doors, to light the area where I operate my Powermatic table saw, the floor model drill press and the Handy-Lift.
And, in a small improvement, I added a bronze bushing for my articulated magnifying lens, so it swivels much-better than just having the post seat in a hole drilled in a two-by block, that the illuminated magnifying lens sits-on, next-to the vise. Both the articulated illuminating lens and the vise are mounted to the same two-by, which is then C-clamped to the 3/16" steel-top 2'X8' workbench tabletop. If I ever needed-to, I can easily remove the vise/lens combo, for whatever project demands more room.
I liked Jim Von Baden's work on what looks-like a BMW boxer R1200 C, the one that James Bond/Pierce Brosnan drove with such skill, while the beautiful female agent was riding in-front of him, but backwards, across the roofs of was it Hong Kong? I've never seen that fairing design before, that'a a lot of lighting! I had an R100RT that I rode back & forth to graduate school here in FL, I always liked the torque of it, and the relative lightness of the boxer engine bikes. One of my friends, a commercial pilot, bought a R1200C when they first were released, and he liked it but he eventually traded it in for a BMW transverse-four K bike. Jim, is that true, your bike is the actual movie stunt bike?
I also need to re-program from scratch my Liftmaster 8500 Elite door overhead openers, as the remote-controlled light I added isn't shutting-off, and the short method of trying to re-program it didn't result in it's operation to shut-off after the programmed number of minutes it's supposed-to.
One of the things I did today that has prompted me to get to-work, is to read this thread. Plenty of good ideas, it's been awhile since I went through a few pages.
Stevie-Ray
Michigan's Sunrise Side
Finally pulled the reverse-faulty snowmobile off it's trailer and put it back on the dollies, and was able then to put my car back in there. :( Hate cleaning snow off a car in the morning.
crewchief888
NW indiana
shoveled my way out to the garage, mixed up some premix, and fired up the snowblower to clear the 5"-6" of snow we got overnight.
in the hour or so it took me to get out to the street, another inch had come down. total snowfall is suppose to be 8"-14" before this storm passes.
sooooo glad i had a vacation day scheduled for today..:thumbup: after working 14hours yesterday...
:beer:
XJSuperman
Central Iowa
Re: What did you do "IN" your garage today?
Worked on my little airtank project. Still deciding how I want the feet to look.
Dan in Pasadena
Pasadena, CA
We recently bought a Class C RV to replace our too-damn-big 36 ft. 5th wheel trailer. Prior to that we had a big Lance 1181 slide-in camper that had a slide out pantry shelving system. My girlfriend liked it so much we adapted it to the 5th wheel. Now, I’ve adapted just the baskets from it and the slide out approach into the narrow pantry shelves in the RV.
The big metal frame system the baskets hung in the camper and 5’er wouldn’t have worked so I built full extension drawer slides into the RV using 1x lumber to clear the cabinet face frame. I also had to shorten the baskets from 24” to 20”. Anyway, it’ll work and makes the girlfriend happy.
Dan in Pasadena
Pasadena, CA
At the same time I’ve been doing the above ^^^^ I’ve also been in process finishing the bed wood on my ‘55 Chevy Truck project. For just plain flat boards it is a pain in the ****. It’s extremely hard to keep drips from forming below as I brush the varnish on the tops and sides. I always go back and check below, brush them out but inevitably a few form and they do NOT full dry even after a couple days.
I end up having to razor them off or wet sand them off which loads the sanding block, etc. I’ve put 4 coats on the tops and the 3rd coat goes on the bottom today. I may stop at 3 on the bottom but I have probably 2 to 4 coats to go onthe top. I plan to give a final sand with 1500 grit and machine polish with 3M products.
stonesfan68
Houston, TX
Are you welding on a pressure vessel? If you’re not certified to do that then it is flat out dangerous to do so. Will you at least hydro test the tank before using it?
I’ve been in the compressor business for 25+ years and I’ve seen some bad things happen when air is explosivly released from a burst tank.
XJSuperman
Central Iowa
Yes it will be tested before any use. No it won't be used much at all. No it's not pressurized in its current state, and no it's not in a public environment where anyone besides myself can get injured if I do something stupid. I think it's still legal to do something dumb, but I havent checked since last week. Also, there won't be very much pressure if I ever do use it, I have other compressors and tanks for use. I appreciate the warning though, thanks.
XJSuperman
Central Iowa
It's not my intention to start fires or antagonize here. Stonesfan68 has very valid points and my response was sincere. This falls into the "don't do this at work" category. If this was going to be used everyday where others besides myself could be in danger I wouldn't be doing it. My actions will be met with my consequences should something fail, and I accept that.
4 FN 27
Minnesnowta
I get it...life is full of choices and they all have consequences, none of them are punishments or rewards until you yourself interpret them they remain consequences. Your choices are none of my business...
Still your statement kicks ***...LOL...
fordkid88
My first thought was that's a no no
KDubU
Kennebunk, Maine
Got only an hour in the garage today. Got more tools installed into the Kaizen foam, connected internet to the garage (powerline ethernet) and unpacked the outdoor light for the man-door - to be installed tomorrow!
Guys, He did say: "Yes it will be tested before any use."
If the welds are well done, and it passes a pressure test, there should not be an issue. My main concern would be many tanks are paper thin these days... Hard to get a decent weld out of that...
Lee Celtic
Llanberis, North Wales UK
All I did today was chop some fire wood..
My youngest needed a car so I spent most of the day driving him the 160 odd mile round trip to pick up our latest Ebay buy..
Citroen saxo VXR hot hatch.. he's a very happy 21 year old right now..Even though some of the drive was a little scary due to the snow..
Oh.. and the feet on tanks have to be welded on by someone..lol .. he said it will be tested so thats all good. :)
That reminds me I have to finish my refrigerator pumped upright compressor build..
niget2002
Josephine, TX
Finally installed some wood storage. Everything you see on the wall was on the ground this morning. The rest of the osb is going to a neighbor tomorrow. I weight tested the pipes by hanging from them. I usually don't end up with very much wide stock left. I'm hoping this will keep the wife from grabbing my oak plywood when she needs to spray paint on something.
Sent from my VS987 using Tapatalk
ezriderga
NW GA
I removed the visors on my MX5 roadster and it did make for a cleaner look however I was almost blinded by the sun yesterday so I put them back on.
NewShockerGuy
Northern Virginia / DC
Pulled the ranger in. Going to be doing chassis saver paint on the frame and on the bottom of the bed over the weekend. Changing fuel filler neck.
Did injectors and replacing valve cover gasket. I forgot to take pictures of the valve cover but I cleaned that up and will paint it a color as well... not sure which color yet. Maybe wrinkle red? I broke my EGR tube so that's on order. Probably won't get done with it till after next week.
-Nigel
cjcocn
Manitoba, Canada
Waiting for a header panel for my 99 Cherokee and trying to keep busy until it gets here tomorrow.
Fixed the leaking windshield reservoir and am going to replace the cowl.
After that it just needs the header panel and I will put it up for sale so I can fund my 93 Cherokee (new floor pans, a mild 3” lift, and I will also make some front and rear bumpers).
Oldbear
Linden, Alberta, Canada
Took a break from building to diagnose a rough idle and do a tune-up on my wife's Yukon and an oil change on my car. New shop has already saved me $420 in shop fees.
Outlander
Quebec, Canada
Having recently had a gout attack I was behind in my million chores. So yesterday I repaired the repair I did to the snowblower (forgot to put the plastic shroud on behind the pull start after getting that fixed (doh!). Then I did the snow clearing not done by my contractor - around the trailer, walkways, to the man door, garbage cans etc.
Tidied up loose tools sitting around on horizontal surfaces, well some of them anyways.
Contemplated where to install the heater Mrs Outlander gave me for Christmas. Still too cold to do that kind of thing, but if it warms a little I can use the bullet heater to make it comfortable.
Changed some flood light bulbs, removed last of the Christmas lights (they were unplugged weeks ago).
Exciting stuff, huh?
