Has anyone done this?
homebuilt burner
central Wisconsin
I had heard of this. When I had my house spray foamed in November I asked the spray foam guy and he indeed had done this already. Then some times they attach the pex for in floor heat to the foam.
EOC_Jason
Bentonville, AR
According to the video:
Compared to blue Dow foam board it carries a 40% higher r-value for the same thickness.
That seems quite significant.
looks like an expensive way to duplicate rigid foam.
rigid foam has been used for years under slabs.
Voi
Western South Dakota
It has been done by at least one GJ member. I don't have the thread bookmarked and it's been a few years at least. I'll see if I can find it.
Showkey
"MEMBER EMERITUS"
Wausau WI
Agree......seems like a very very expensive way to insulate when foam board would function perfectly at a fraction of the cost. 40% increase in R value at 4 times the cost ???????
iagsxr
Vinton, Iowa
When I built my shop one of the heating contractors I had bid it suggested we insulate under the slab that way.
I don't remember the exact numbers but it was significantly more than rigid foam.
K'ledgeBldr
Johns Creek, GA
Yep- not exactly hard math!
Plus TIME! And the spray foam was not going very fast compared to 32s/f every 10-15sec.
small&rusty
Idaho
Company I work for build a house last year and used spray foam under the slab. It was the first and last slab they will ever use spray foam under. After the floor was poured it cracked everywhere, one spot even had the in floor heat tubes showing due to the foam thickness varying so much under the concrete.
Firstram
Did they use foam with enough density? Spray foam can be as hard as a Brick Bat or as soft as Angel Food Cake, depending on the product applied. Proper installation is VERY important to avoid holidays and excessive buildup.
MikeF2316
Thornhill, ON
Yes, sounds like they shouldn't have even poured the concrete in the first place. But that's the trouble today - there's too many people passing themselves off as skilled doing a half-*** job.
69gp
Closed cell foam is extremely strong, I weigh in at 260lbs. On a commercial project i was working on the roof was framed with trusses on 24" centers. attached to the bottom was hat channel and 5/8 rock. Rock was all taped. Insulation company came in and sprayed 2" of closed cell across the whole ceiling. Next day you could walk wherever you wanted on that insulation without any fear of falling through. That stuff is tuff
LS6 Tommy
Northern NJ
Those types of issues caused by uneven material thickness & density was the first thing that popped into my head...
Tommy
ynned
N.E. Ohio
As stated a couple times already, keeping the top of the foam on grade seems really hard to do. The slab could vary in thickness by a couple inches or more.
dfiler2
NW Minnesota
It seems to me it would be a really slow tedious process, maybe not? The only thing worse than working over your head all day is working bent over like that:)
bwringer
Indianapolis
Yeah, I was also wondering why the hell the nozzle couldn't be two feet longer so the guy doesn't have to be all hunched over like that.
nelstomlinson
Interior Alaska
Rigid foam under concrete is cheap, especially if you can buy it used. Who cares about R-values per inch? Just dig a few inches deeper and use enough used, cheap rigid foam to get the R-value you want.
