I picked up this Samsonia Perfect No 38 Model J (5" jaws -45#). I THINK it's supposed to be a quick adjust but the lever mechanism is missing and I can't figure out how it's supposed to work
Quite a bit of info available on the vise itself but can't seem to find any pics of the underside. Any help would be appreciated.
RagTop, I have to agree with Lis2323.---Simplest and quickest is O A torch.---Don't have to heat it plum cherry red, just plenty of heat all around the channel at the bend to keep it malleable, while it's mounted in a hydraulic press, and it should straiten right up.---Same with the screw.---Don't go hog wild and then have to flip them over and straiten from the other side.---Press a little and check, press a little and check.
RagTop, I have to agree with Lis2323.---Simplest and quickest is O A torch.---Don't have to heat it plum cherry red, just plenty of heat all around the channel at the bend to keep it malleable, while it's mounted in a hydraulic press, and it should straighten right up.---Same with the screw.---Don't go hog wild and then have to flip them over and straighten from the other side.---Press a little and check, press a little and check.
Perfect advise for Rag Top! I just checked his profile for location. A LITTLE too far away otherwise he'd be welcome to come over to get it straightened.
Thanks for the infofellas, we have O A Torch but buddy across the alley has the press. I'm gonna give it a shot next day I get to mess with it! I can't wait to get it back in shape!
That's a buttress thread on the screw, but that's not the typical half nut. Hard to tell whether that's factory or not, with never having seen a plain version. That nut looks of better quality than I'd expect for a user mod though.
What does that writing on the nut say?
dutchgray and Fretters take a look at the underside of my Smithsonia and see what you think.
You will notice that the first couple of inches of thread on the screw are missing. (This does not affect the function of the vise)
Lis2323, I wished you did have a Smithsonia, it would be a one of a kind and I wouldn't rest till I owned it.---Sure would like to know how those threads got sheared.---That took some serious cranking.
This little 2 1/2" Miller Falls value line (cheap) vise was fun to restore. I had to make a new spindle handle and a cup washer for the mounting screw. The label couldn't be saved so I made a similar one. I thought the swivel base on the economy line vise is a nice feature.
Look what I found today at an Estate sale!
RTop, those formed steel slides are malleable, so could be straightened cold, however some local heat will make it so less pressure is required, and you are less likely to fracture the jaw casting its in.
All you should need is to where its just barely starting to glow. Have the press and any blocking ready to go. The only concern would be that curved top section. You don't want to deform or flatten it. Can you find or make a block with the same curved saddle, and use that between the press ram and the slide?
I compared the two when I got the value line model. The 1700 is exactly the same so I would guess it was a marketing thing. The silver & red is a bit more eye catching than boring black.
Looking at that photo again, the front plate looks like it has been cast to that shape rather than the lever holder having sheared, so I'm guessing that's probably as supplied from factory. I'm guessing those two holes either side of the nut aren't threaded?
Found a passed for sale ad, and it listed 127 lbs.
Found another adv.
akasrick
007: Hollands are on par with REEDS in heft, quality and almost a copy if you ask me if the names weren't stamped different on their sides. i had a Holland's 15 and 14 that i sold a young member that needed a good vise for the bench he was going to build a few years ago and I've asked him several times to sell me back the vise and include the bench and old metal kitchen cabinets for a bit more and he has continued to DECLINE MY REQUESTS.
I'd say Get's Holland's catalog page listing it at 127 pounds is about right for it's weight and maybe Riley weighed his before he sold it. or maybe the guy that painted it yellow knows it's weight.
Riley's Holland's 16 is a nice vise and no wonder his co workers love it. I just lifted this REED 106 on this stand into my Honda and dang i almost dropped it, but i didn't want to spend the time removing the stand. it's got to come out of my storage that i'm vacating where it was pretty useful, but i'm sure i'll find a good spot for it here.
