FallibleFlyer
I am in the process of rebuilding my welding table and have ran into a dilemma that I would like some input on. My new table's frame can be seen in my garage thread post, here. I have a few options for the top and they each have their own questions/issues.
The frame is built out of 16ga 1.5" square tubing and made to accommodate a top just over 2'x3' if that helps for relative scale.
- I could reuse my current welding top, which is comprised of two cast iron table saw tops. They have made a pretty solid welding table for the last five years or so. They're easy to clean, quite hard, and only have a couple low spots (under 1/16th") making it not too difficult to create flat work.
- As stated they're not perfectly flat. Would I realistically get flatter from just plate/flat bar setup?
- Clamping is challending due to the uneven underside and large lip on the edge.
- I could place down a solid 3/8-1/2" plate.
- Would be a solid option and reasonably flat.
- How the heck does everyone move these pieces around? I have no chain hoist, no engine hoist, etc. We just moved here, so I lack strong friends. Do I have an "easy" option to move a 120lb+ piece of plate without hurting myself alone?
- I could build it out of 0.5x6" flat bars.
- I've seen a number of builds done with 1.5" gaps between the flat bars and bolts used to level the top. I'd likely replicate this.
- Are the edges of this thickness of flatbar rounded at all? Whenever I've gotten 1/8" flat bar, the edges always have a slightly rounded edge, and they've never seemed truly flat across their surface. Is this true with the thicker material?
