Is there a Hi-Flow version push connect coupler?
2004EP3HATCH
Hi guys,
I bought the husky one to try to help with blowing my tool out of the coupler when changing them. It’s time consuming having to turn the pressure down each time. I use multiple tools at the same time sometimes. I guess I could have multiple hoses run, but I think for my application, this would be easier.
I use 1/4inxh Hi-Flow Milton V couplers and the husky ones. The husky push connect coupler that’s supposed to not release air when disconnecting,
Is a Universal coupler. It just does not work
With hi-Flow plugs. Any input on this? I did search it, but not really helping.
Sorry the picture is sideways. It’s not the way I took it.
Bellaireroad
Fort Worth
Prevost
Works great
ItsNemo
Canada
All plugs will lose some air when disconnecting...there's air between the coupler and the trigger of whatever tool you're using.
2004EP3HATCH
I know that, a little is ok. But this is supposed to help reduce it and reconnect. I’ll check it out.
alan camby
South of Indianapolis, Indiana
I use industrial 3/8" body couplings and plugs. They are available with the common 1/4" npt ends and have much larger internals. Most people are using the cheaper 1/4" body fittings and plugs.
my couplers are Prevost brand
jptbay
http://ariatools-inc.com/product-category/couplers/
2004EP3HATCH
I’m using Hi-Flow 1/4 plugs. They measure about the same as 3/8th internally. I was going to switch until I saw there was almost no gain, but having larger plugs and couplers to drag around. I can take a measurement again. If I went G series, that’s 99CFM!
tarmy
Nor Cal
Prevost
Works great
This...there are different versions of this...so do a bit of research to figure out which works for you set up...they are a bit pricey...but worth it.:rocker:
Skin
Boston
Not sure if the actual coupler is high flow but I have to say I've been very pleased with Coilhose universal (5 in 1) safety coupler. It will connect to just about every common male fitting including hi-flo. They've held up a lot better than the plastic safety couplers like posted above. After a few months of hitting the floor those plastic ones seem to break inside.
ultgar
New Jersey
I sell Prevost and the Euro High Flow profile is the their most popular. If you've already got 20+ tools with a different profile, stick with that. But if you're just starting out, the "green button" Prevost couplers do flow more air (see air plug comarison photo).
