Replacing Husky wrenches with Armstrong/Proto
Tallpilot
Orlando
Also my current method, I've noticed the truck around as I go about my business, just stop and get one every few weeks.
I had to check this as I have 2 20mm gearwrench, neither of mine is reversible which I believe is what you were referring to and it seems that there isn't a 20mm reversible. Very odd to my way of thinking but on the other hand I've rarely had to deal with the random 20mm.
Reversible or flex head. You have a zero offset ratcheting combination?
2004EP3HATCH
FYI, Williams makes both Taiwan and USA tools that are identical to Snap-On offerings - Williams Taiwan is the same as Blue Point, and Williams USA is the same as Snap-On. If you want the latter you can buy Williams USA and get the same tool while saving money.
Interesting. It seems all these companies make a US and Taiwanese version.
2004EP3HATCH
For those interested, the whole gearwrench combo reversible with offset below:
2004EP3HATCH
Have you decided on a set of wrenches yet? You started this thread way back on February the 8th.
Yes, I have bought these sofar. All reversible combo ratcheting with 15 degree offset.
6MM - PROTO USA
7MM - PROTO USA
8-14MM - Armstrong
15MM Matco (same as Armstrong)
16-19MM - Armstrong
20 - K-Tool
21,22MM - proto USA
xin
ARKANSAS - NWA
6MM - PROTO USA
7MM - PROTO USA
8-14MM - Armstrong
16-19MM - Armstrong
20 - K-Tool
21,22MM - proto USA
Does the 6mm/7mm have the teeth in the open end?
2004EP3HATCH
