Best Source for "Bulk" Wire?
kythri
Lebanon, OR
Where's the current "best" source for decent quality copper wire? Looking to pick up a few 100' spools of a few different AWG sizes in a few different colors.
malibu101
Walnutport PA
Besides the AWG gauge, the bigger question is what kind of insulation on the wire do you need?
Are you wiring a house or a car?
K
kythri
Lebanon, OR
This would be for automotive and other DC type work. Not any kind of paired conductor stuff.
Looking at various AWG - anywhere from 2 to 20 (or is that 20 to 2?).
FigureItOut
Bentonville AR
I use waytekwire.com. Del City is another popular supplier but I've personally gotten a little frustrated with them on a couple occasions. Both provide good quality wire in a large variety of sizes and colors at a good price. Waytek if I remember gives more details about the characteristics and specs of the different insulation choices.
Locally, Napa usually carries good quality in spools or by the foot, most of the selection will not be out, you have to ask.
JBH
Apex Jr, if you're interested in silver-plated mil-spec stuff with PTFE insulation
6PTsocket
I see your point about wire size. It brings up a funny memory. I needed insulated faston connectors at work. I think they were the red ones for 18 to 22 gauge. I sent a note to our stock clerk with a skew, for Grainger. She did not order them because:" "I asked for 18 to 22 and the ones in the catalog were 22 to 18". You can't make this stuff up.
Dave455
Sussex, England
Don't know about the U.S. but here in the U.K. I source all my wire from an electrical fitting wholesaler. Because they get through so much wire and cable they get a really good deal from the suppliers, and you can order anything!
matt_i
SE Michigan
I gave up on PVC grade wire and use THHN these days. I'm just doing small additive stuff or building simple wire harnesses for my tractors, not making stuff for sale where the volume cost would be a thing. And it carries right over into doing AC and DC control wiring for other automation type projects.
turbodave
IL/WI
I've been happy with Waytek, good descriptions and good products, just a bit expensive on the shipping. I've found some decent deals on Amazon as well.
Bert_
NW Iowa
I use partial rolls of MTW that are left over electrical jobs. Have several colors in 18-12 gauge. Full 500' spools are available from many electrical suppliers.
K
kythri
Lebanon, OR
Isn't THHN a covering over PVC?
K
kythri
Lebanon, OR
I have an account with Anixter for my day job, so I'm sure I could get them to sell to me outside of that, just hadn't thought of them for this, which was a dumb idea on my part - I don't buy electrical components from them, so I blank that they sell a hell of a lot more than what I buy.
I'll have to ping my account manager and see what kind of prices they can get me.
K
kythri
Lebanon, OR
And thanks to everyone else for the other suggestions! I'm evaluating them, but shipping seems to kill most deals over a local-ish purchase, sadly. :(
Bad Habit
Chumstick WA
That's the rub. For what you're looking for though, if you can't find at a local electronics/hardware store, you're probably going to be better off with a Waytech, Del City, or Remy Battery, even with shipping. You maybe able to get a "good guy" deal at Anixter, but they won't cut the smaller sizes and may not even have what you're looking for. Same with Graybar, Windy City Wire, CSC, etc
theoldwizard1
SE MI
There is a lot of inexpensive wire on eBay, but you have to know what is "cheap" and what is good.
First, "primary" or "hook-up) wire usually has insulation that is rated to only about 50-60V. Fine for automotive use. "Marine" grade wire is great for automotive use because each individual stranded is tinned and it will not corrode.
Insulation is also rated by temperature, an issue if you are soldering. UL 1015 wire is good to 105C (221F). UL 1007 is only good for 80C (176F). There are newer "standards" for automotive use that use cross-linked polyethylene insulation (GXL is most common). A bit more expensive, but thinner and higher temperature rated (125C)
When you get above that, I'm not very good ! Typical "house" wire is only rated for 300V. The next step up is 600V. There are dozens of different type of insulation. Many over lap specified usage, but THHN and THWN are commonly use for branch circuits inside of a conduit.
EDIT : Any PVC insulation will degrade/swell/fall apart when exposed to oil for long periods which is why the automotive industry switched to cross-linked polyethylene.
Jason280
How does MTW do in an automotive application?
BaMaDuDe87
AL
Re: Best Source for "Bulk" Wire?
Haven't looked in awhile, but check monoprice.com?
blarf
Waytek often has low prices, but my last order for ATM/DTM components went to Mouser because they were about half the cost of Waytek so it definitely helps to shop around. Of course my big problems with Waytek are that the site is slow and clunky and that their support is pretty much non-existent. UPS lost my last Waytek order and the official Waytek response (which itself took a couple phone calls) was "here are all the things we could do, but we won't." There are plenty of places to buy wire, but with that attitude I wouldn't bother with Waytek.
